Author Topic: Advise Please  (Read 3217 times)
JoeBirt
Advise Please
« on: 12 November 2008, 11:37:17 »
I have an Omega Elite V6 - The headgasket right bank has gone - Is it worth spending the money to replace it (146000 + Miles - No Mot Susspesion Bushes OSF and two Tyres and NSF Dip Headlight no Pattern) or is time to send this miggy to the great Miggy graveyard? :-/
jonathanh
  • coventry
Re: Advise Please
« Reply #1 on: 12 November 2008, 11:59:04 »
are you sure it is the HG?  symptoms?
often mis diagnosed for oil cooler or HBV failure
JoeBirt
Re: Advise Please
« Reply #2 on: 12 November 2008, 12:16:46 »
Symptons are
Starts fine - When warm starts to miss and feel lumpy - Pulled No 3 Plug (RH Bank Centre) loads of water on the plug
BTW what is HBV?
Welung666
Re: Advise Please
« Reply #3 on: 12 November 2008, 12:18:08 »
HBV = Heater By-pass Valve :y
Any oil in the expansion tank or mayonaise looking gunge on the dipstick?
JoeBirt
Re: Advise Please
« Reply #4 on: 12 November 2008, 12:34:46 »
Expansion tank looks oily and Mayo on Oil Filler cap
Welung666
Re: Advise Please
« Reply #5 on: 12 November 2008, 13:03:12 »
More than likely oil cooler then :y
JoeBirt
Re: Advise Please
« Reply #6 on: 12 November 2008, 13:40:43 »
Scuse my ignorance bu is tis adifficult job?
Welung666
Re: Advise Please
« Reply #7 on: 12 November 2008, 13:50:49 »
Fairly difficult, there is a HowTo here :y
JoeBirt
Re: Advise Please
« Reply #8 on: 12 November 2008, 14:11:24 »
thanks for that I will look into it before making my mind up :y Unless anyone knows of a good mech aroundthe Surrey Camberley Area?
« Last Edit: 12 November 2008, 16:02:27 by JoeBirt »
Re: Advise Please
« Reply #9 on: 12 November 2008, 19:13:45 »
Mayo on the inside of the oil filler is generally because the car has been doing short journeys, using Vauxhalls oil goes someway to curing this. Oil in the water is more than likely the oil cooler as said above ;)
« Last Edit: 12 November 2008, 19:14:24 by Elite_Pete »
Bandit127
Re: Advise Please
« Reply #10 on: 12 November 2008, 19:41:06 »
If it was the oil cooler - would it cause these symptoms?
I reckon a compression test is in order first...
JoeBirt
Re: Advise Please
« Reply #11 on: 13 November 2008, 15:19:33 »
Actually there is water in the cylinder head - pulled one plug and it was soaking :(
JoeBirt
Re: Advise Please
« Reply #12 on: 21 November 2008, 11:48:10 »
If no one is intrested in saving this Elite - It will be going tothe Graet Miggy Scrapyard in th Sky 30th Nov 08 - I would break it myself but donot have the space - Another one bits the dust :'(
markey mark
  • SLady bitshorpe north lincs
Re: Advise Please
« Reply #13 on: 21 November 2008, 12:06:40 »
were you based joe ?? and how much mate ??
Re: Advise Please
« Reply #14 on: 21 November 2008, 13:36:43 »
Have you confirmed there's coolant leaking into the cylinders? Sounds to me like it could just be a leak from the scuttle area filling up the plug wells with water and causing a misfire. :-/
I am in the Camberley area occasionally if you want a second opinion.
