Author Topic: Windscreen Wipers  (Read 1185 times)
Edd
  • South Ockendon
Windscreen Wipers
« on: 24 November 2008, 20:30:03 »
Hi there, found another fault today. The windscreen wipers dont always turn off when switched to do so. Is this just a switch problem or is it more in depth
Once again thanks in advance
Edd
Re: Windscreen Wipers
« Reply #1 on: 25 November 2008, 00:40:27 »
dont know Edd, but im sure someone will have a suggestion soon. Bump.
Er they're not rain sensing are they. No, just a thought...
« Reply #2 on: 25 November 2008, 08:37:50 »
I'm sure Kevin will be along sometime soon ::)
IIRC, I think it's the contacts in the motor itself?
Kev had this issue, I'm sure he'll advise on what caused it :y
« Reply #3 on: 25 November 2008, 10:08:30 »
It was indeed the motor in my case.
If it gets really frustrating you can remove the wiper delay relay from the engine bay fuse box. The wipers won't auto-park but they'll at least stop when you want them to. I fitted a used motor. Not a bad job. Scuttle off, wiper frame out and swap the motor over. Good opportunity to pop the ball joints on the wiper levers and give them a clean and some fresh grease.
Edd
  • South Ockendon
« Reply #4 on: 25 November 2008, 12:30:44 »
Thanks Kevin, I will check out the relay first thanks
