Author Topic: No hot air thru driver`s vent in a facelift  (Read 1926 times)
m1ct
« on: 23 November 2008, 19:50:01 »
Like above- although the temp is set for eg.28'C and hot air comes out other vents, the driver`s one blows cold air... I think Robsey`s already checked the centre panel and pipes around hbv etc.
Any ideas? Thanks in advance!
Marti
Re: No hot air thru driver`s vent in a facelift
« Reply #1 on: 23 November 2008, 20:37:11 »
drivers vent? Centre or window?
m1ct
« Reply #2 on: 23 November 2008, 20:49:42 »
the window/door one
« Reply #3 on: 23 November 2008, 21:02:34 »
ah, ok. Mine has very little from the centre vent with the latest software. So not that then. Can only suggest the reset the vents trick, auto and off together for 5 seconds or so with ignition on engine off. Failing that a trip to see Kevin in Alton for a tech 2 fiddle. Mite be the vent motor gone if all the vac pipes are ok and not leaking anyware.
m1ct
« Reply #4 on: 23 November 2008, 21:12:24 »
will try that in a sec
[Failing that a trip to see Kevin in Alton for a tech 2 fiddle]
yup, very local indeed :)
m1ct
« Reply #5 on: 23 November 2008, 21:20:20 »
well, just tried resetting- no luck. Gonna have to wait till Saturday when we`re having a mini meet at our place and Tom`s bringing his tech2. We hope it`ll cure the cold blow :) thx Chris
« Reply #6 on: 23 November 2008, 22:38:47 »
Hmmm strange, one vent not blowing warm air? presumeably you've tried all the direction vent buttons to try to get it moveing? beyond my experience tbh :-/, maybe a more experienced member has something to try while you wait for tech 2  :)
« Last Edit: 23 November 2008, 22:41:14 by chrisgixer »
« Reply #7 on: 26 November 2008, 01:17:13 »
Hi guys, this came up recently. Hope helps.
http://www.omegaowners.com/forum/YaBB.pl?num=1227632109
