Author Topic: oil in plg wells, missing like a bitch(under load)  (Read 1614 times)
gravygranules
  • southampton
« on: 25 November 2008, 21:17:43 »
some 6 mnths ago i had oil in the plug wells and a friend of mine tried to  put it right (including changing the cam belt) but my 2.0 petrol omega has started 'missing' under loadand the rear 2 plug wells have oil in them.if i want to do this myself (and im a complete amatuer)should i attept it?.i believe its the cam seals?..or rocker cover seal?...same  thing?...ive cleaned out the 2 breather hoses on the top of the engine and unblocked the small one on the throttle thingy(with a fine piece of wire and a can of carb cleaner also done the throttle valve thing with carb cleaner too. any help appreciated, thanks..yea i kno im a numpty...
Re: oil in plg wells, missing like a bitch(under load)
« Reply #1 on: 25 November 2008, 21:18:27 »
were genuine gaskets used last time around?
ians
  • Reading
« Reply #2 on: 25 November 2008, 21:45:50 »
Its not a difficult job on a 2.0 but consensus is you need to use GM seals and not overtorqued the camcover bolts.
« Reply #3 on: 25 November 2008, 22:04:37 »
No numps here, we are all learning, gotta start somewhere. Give it a go, much easier than the v6 when al sorts of stuff has to come off first. As said
genuine gaskits and torque the bolts correctly. I "presume" its 8nm same as the v engine?
Might be worth a look in maintenance section for the clean breathers guide just to be double belt and braces, if you havent already. Hth
gravygranules
  • southampton
« Reply #4 on: 25 November 2008, 23:45:53 »
dont think genuine gaskets were used.. and do i need a sealant of some sort?...im dreading it but im gonna give it a go...sigh....thanks for the help
« Reply #5 on: 26 November 2008, 00:20:19 »
Yes, need black goo. Used to be loctite 598 but they superceded it with another number, which i cant remember...maybe ask the Halfords lad for the equivalent. Unless someone on here knows?
 Only use black goo round the cam cut outs/half moons at either end,  just round the detailed areas in the corners. Dont use it  the whole way round as you will seal what is a pressure release valve in effect. If the crank case pressure cant escape from the cover, the next easiest place for it to blow is the crank pulley seal. And that job IS a pita.
Maybe while your in Halfords get yourself a small torque wrench, if you cant borrow one. :-)
Ps if you need to change the plugs, i would, they are cheapest at vx, they also do four pot rubbers for the spark plug caps, or a motor factors for a complete set of leads, vx aint cheap for leads iirc, if it still runs rough, then you or on to the dis pac. But first step is the cam cover and keeping the oil out of the wells/in the engine.
Oh, Probably need some o rings for the cam cover bolt and plug holes too. Hth.
« Last Edit: 26 November 2008, 00:31:44 by chrisgixer »
« Reply #6 on: 26 November 2008, 00:27:54 »
Where are you from Gravy?
gravygranules
  • southampton
« Reply #7 on: 26 November 2008, 01:04:24 »
thanks for the help chaps, southampton here
« Reply #8 on: 26 November 2008, 01:05:42 »
I'm in Portsmouth on Friday  ::)
« Reply #9 on: 26 November 2008, 01:22:06 »
 James will sort you out, highly recommended. An experienced eye... Def worth a chat.
« Reply #10 on: 26 November 2008, 01:25:30 »
I'm doing a cambelt change over there (for a VXON member ::) ) - Just thinking I could swing over and pop these gaskets/leads on, if gravy can get them - it can't take too long...  :y
