Author Topic: Headlight Confusion  (Read 2747 times)
warnysouth
  • London
Headlight Confusion
« on: 27 November 2008, 10:55:48 »
Hi all,
I've just got hold of an 'M-reg' 94/95 Omega Elite. Its fine, apart from the headlights are so bad they are nearly dangerous.
Having read many of the threads on this forum (and others), I am still slightly confused. The car is only worth about £250 so I really dont want to have to spend much money (certainly no more than £100) to improve them.  I know the lights have a switch inside to move them up and down, and I think they have washers. I have the self levelling suspension.
Now, the way I understand it, I have several options
1) Upgrade bulbls - cheap, but probably still rubbish
2) Install aftermarket HIDS - I've done this on my other vehicle for the grand sum of £70 (with ballast and all) and they are fantastic, but people are talking about £200 for HID kits for the Omega - is this right?
3) Replace headlamps with later (CDX?) projection units
My questions is, therefore, how good are the CDX units, and how much should I expect to pay for a secondhand set, and, has anyone got any?!
Any help is much apprecaited!
Many Thanks,
Scott
« Last Edit: 27 November 2008, 10:57:37 by warnysouth »
markey mark
  • SLady bitshorpe north lincs
Re: Headlight Confusion
« Reply #1 on: 27 November 2008, 10:58:21 »
as you have an elite get a set of hid xenon headlamp units from later model elite say 98 onwards makes a massive difference  :y
warnysouth
  • London
« Reply #2 on: 27 November 2008, 11:15:03 »
Thanks Mark, but where can I get some, and how much should I expect to pay?
Scott
markey mark
« Reply #3 on: 27 November 2008, 11:25:57 »
i havnt got any at min ! mabye chris (mutantcav) has some around £100/120 inc delivery is the going rate but that includes everything bud ! :y :y
MutantCav
  • Gainsborough
« Reply #4 on: 27 November 2008, 11:29:59 »
Agreed going rate for genuine second hand ones about £100 plus postage (approx 15-20)...I had 5 sets, sold 2, 2 were broke and sold ballast packs...not 100% sure if I have any left or not, depends what the last set is like...as said on an elite, nothing needed beause of self levelling rear suspension other than some minor rewiring...
Alternatively the projetor headlights from later 98 on models have clear glass and are better, but HID's are distintly MUCH better  :y
warnysouth
  • London
« Reply #5 on: 27 November 2008, 11:38:06 »
So the ones you sold were HID ones?
warnysouth
  • London
« Reply #6 on: 27 November 2008, 11:47:23 »
PS are the 94/95 Omega lamps H1 fitment?
Scott
markey mark
« Reply #7 on: 27 November 2008, 11:56:51 »
Scott
yes h1 all round on early models  :y
i might have a set of projectors for sale very soon minters as well then you could get one of the hid kits from ebay ! :y
warnysouth
  • London
« Reply #8 on: 27 November 2008, 12:00:09 »
Mark I'm confused, can I not fit the HID kits to my existing lamps?
So there are 3 types of Omega headlamps
Early rubbish ones (like mine)
Later HID ones (like the ones you sold 5 sets of)
Even later projector ones (CDX one).
That right?
markey mark
« Reply #9 on: 27 November 2008, 12:13:30 »
That right?
yes you can but being the ribbed style a bit of a waste
from 98ish onwards the omega had projector stlye lamps much better than the early ones but still not great ! 98ish onwards the elite and mv6 had hids fitted these are much better ! all 98 onwards omegas had the projectors apart from the elite and mv6 !  :y
warnysouth
  • London
« Reply #10 on: 27 November 2008, 12:34:10 »
Right,
So I could fit the HID kits from ebay like in this post:
Hi,
Had same problem. Fitted clear lens headlights - no good. Fitted brighter bulbs - no good. Bought an H.I.D. conversion kit for £60 + £10 postage (J.A.M. Performance) on ebay. Plug and play, no modifications needed, easy as you like, solves the problem. Bright blue/white  lights that make you actually see where you are going.
Fredsta
But because of the ribbed lens they will still be rubbish?
How much is a secondhand set of Elite HIDS (post 98) ones?
Cheers
Scott
« Last Edit: 27 November 2008, 12:34:57 by warnysouth »
MutantCav
  • Gainsborough
« Reply #11 on: 27 November 2008, 12:42:01 »
As said, second hand set of elite HID's with ballast packs about £100 plus postage and yes they are the ones I have been selling recently...
You could fit the kits BUT they are illegal to fit to a non HID designed headlight...
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #12 on: 27 November 2008, 12:42:24 »
Right,
Hi,
Fredsta
Cheers
Scott
going rates about 100 pounds as either markey or mutantcav mentioned,
you might find an mv6 being broken for spares- i looked on ebay and there were alot of projectors but it's wether they're hids or not (they look the same but hids have the ballast pack on the bottom)
« Last Edit: 27 November 2008, 12:43:01 by grainqey »
V8!!!!
warnysouth
  • London
« Reply #13 on: 27 November 2008, 12:48:55 »
OK, thanks all, understood, I will look out for a set of factory HID lamps,
Thanks again,
Scott
MutantCav
  • Gainsborough
« Reply #14 on: 27 November 2008, 13:01:21 »
I will check the ones I have left and see if they are any good...
