Author Topic: Carb Or Wd40  (Read 1749 times)
laurie
  • headley down, hampshire
Carb Or Wd40
« on: 28 November 2008, 15:26:58 »
Can you use WD40 instead of carb cleaner to clean the breathers?
Re: Carb Or Wd40
« Reply #1 on: 28 November 2008, 15:28:42 »
Wd40 is not efficient for cleaning like a carb cleaner..
Re: Carb Or Wd40
« Reply #2 on: 28 November 2008, 15:33:04 »
Nope, although petrol works quite well (some carb cleaner is little more than petrol!)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: Carb Or Wd40
« Reply #3 on: 28 November 2008, 15:44:10 »
at work we use a similar oil to wd40 as rustguard- could even be wd40 under an industrial brand name!
« Last Edit: 28 November 2008, 15:44:24 by grainqey »
V8!!!!
Techno
  • Bedfordshire
Re: Carb Or Wd40
« Reply #4 on: 28 November 2008, 15:55:46 »
 WD40 will clean things in fact I find it quite good for removing crud off metal parts it works wonders on motorbike chain but it will leave a residual, it hasn't got the ability to instantly remove oil/grease for a spotless clean though.
I find it good at removing the crud in the smaller pipe and unions and it being an oil can actually help stop further build up.  ;)
holtender
  • Suffolk
    • 2.5 CDX Facelift
Re: Carb Or Wd40
« Reply #5 on: 28 November 2008, 16:22:06 »
WD40 is fantastic for renovating faded plastic guttering, try it!
senny1427
Re: Carb Or Wd40
« Reply #6 on: 28 November 2008, 17:54:51 »
Kerosene is excellent for cleaning/de-greasing if you can get your hands on any...
Re: Carb Or Wd40
« Reply #7 on: 28 November 2008, 18:55:01 »
We call it parafin in the UK ...... ;) :y clicky
