Author Topic: WARNING LIGHTS  (Read 1919 times)
dangles
WARNING LIGHTS
« on: 28 November 2008, 16:40:14 »
i have a big problem here. my abs and traction control light has come up on the dashboard rendering my speedometer useless. in other words when those lights appear the speedo stops working. at first it would go away after a while but now the warning lights stay on permanently and of course i now have no speedo.  help......
bobbertbear
  • perth
    • 04 omega 3.2 ex plod
Re: WARNING LIGHTS
« Reply #1 on: 28 November 2008, 18:03:07 »
abs sensor on the blink methinks
Re: WARNING LIGHTS
« Reply #2 on: 28 November 2008, 18:18:32 »
Could be the ABS ECU :(
belldarr
Re: WARNING LIGHTS
« Reply #3 on: 28 November 2008, 20:28:34 »
This almost certainly is the ABS ECU - does the steering go heavy as well??
Lots of posts on this very common problem if you use the search  :y
Darren
Re: WARNING LIGHTS
« Reply #4 on: 28 November 2008, 20:57:21 »
Definitely ABS sensor breaked - look for previous posts on here.
Re: WARNING LIGHTS
« Reply #5 on: 29 November 2008, 09:15:11 »
abs ecu cabbaged...breakers on here or recon.
Bba reman on google.
http://www.omegaowners.com/forum/YaBB.pl?num=1152729807
Newer cars i believe the ecu is somewhat more accesable. Fill in your profile with year, car, and location, may be able to direct you further.
« Last Edit: 29 November 2008, 09:29:51 by chrisgixer »
Page created in 0.008 seconds with 16 queries.
