Author Topic: EGR Blanking  (Read 1939 times)
laurie
  • headley down, hampshire
EGR Blanking
« on: 28 November 2008, 12:44:18 »
HI
Can anyone point me to a link or pics on how to blank the EGR. I have read several threads that say this can be done. looking at the EGR on the V6, is it a matter of disconnecting the connector or what, please advise.
Thx
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: EGR Blanking
« Reply #1 on: 28 November 2008, 12:47:34 »
HI
Thx
afaik laurie it's a matter of taking the egr off the plenium, putting a plate over it or similar to block it off(needs to be airtight though) then block the copper pipe coming from the cylinder head
V8!!!!
MutantCav
  • Gainsborough
Re: EGR Blanking
« Reply #2 on: 28 November 2008, 12:52:00 »
Its a matter of removing the top part of the EGR...removing the copper coloured plate, flattening out a bit of coke can and cutting it to the shape of the plate using the plate as a template, then making holes for the bolt but leaving the centre bit still filled...then stiking it all bak on with the bit of coke can on top of the plate to stop the airflow getting into the EGR valve, really simple...
Re: EGR Blanking
« Reply #3 on: 28 November 2008, 12:52:28 »
and dont plug off the egr..
MutantCav
  • Gainsborough
Re: EGR Blanking
« Reply #4 on: 28 November 2008, 12:55:28 »
Yeah ignore what Alex said lol Leave EGR plugged in, and do not block pipe :) just the homemade coke can plate slipped in above the existing plate/gasket
ngrainqey
  • rotherham
Re: EGR Blanking
« Reply #5 on: 28 November 2008, 12:56:43 »
lmao...oh so it's as easy as that?
i was thinking practically see... could sell the egr if any good my way :P
V8!!!!
senny1427
Re: EGR Blanking
« Reply #6 on: 28 November 2008, 17:57:51 »
What is the reason for this mod??? does it affect fuel consumption/performance ???
Re: EGR Blanking
« Reply #7 on: 28 November 2008, 18:10:05 »
fuel consumption drops nearly half a liter per 100 km if my MID is not wrong..Perfomance slightly better..
frank1
  • telford
Re: EGR Blanking
« Reply #8 on: 28 November 2008, 21:36:54 »
a 2pence piece is ofton just the right size, put it in either end of the pipe that goes from the exhaust to the inlet, job done
Techno
  • Bedfordshire
Re: EGR Blanking
« Reply #9 on: 28 November 2008, 23:09:43 »
As the man said what does this mod do in real terms?
Re: EGR Blanking
« Reply #10 on: 28 November 2008, 23:41:58 »
It's a good diagnostic step if you suspect the valve is leaking, otherwise, not a lot. Fuel consumption slightly worse, as said. Might be a little more responsive although the valve shuts on full load anyway.
nabsim
  • High Peak
Re: EGR Blanking
« Reply #11 on: 29 November 2008, 09:47:40 »
One of the guys on vvoc ended up with head damage a sliver of steel got in from the exhaust side of the EGR into the inlet. After he discovered this is where the sliver came from there were a few other guys with same damage that VX could not find the cause. It is worth blanking off just to save this happening although none of them could verify performance increases on a RR. This was with V6 vecs though so may be different on Omegas.
