Author Topic: water leak  (Read 1653 times)
valet2002
  • Luton Bedfordshire
  • always happy to help
water leak
« on: 29 November 2008, 18:35:25 »
Hi to all, I have had my 2.5 Auto Elite now for about a month and in that month I went on a long drive to norfolk the car drove perfect there and back, but 2 days after I noticed that the on board comp was telling me to check the coolent when i got home i did so and noticed that water was running out from the right side of the engine at the back ?  :-/ I thought that it was the hbv but was not that,  :( I was told to check the coolent pipe that runs round the back of the engine, so i took all the pipes off of the hbv and then unbolted the pipe off the the back of engine,  :'( what a task that was  :-/ I noticed that the o ring was no good and needed replacing  so done that and put all back together tested all ok But was not what I thought it was its still leaking from the back of engine and i cant see where its coming from  :) can any one addvise me cheers  :y
john
iainb
  • West Midlands
Re: water leak
« Reply #1 on: 29 November 2008, 18:47:42 »
The hose clips that secures the hose's to the HBV can and do dig in, I was in your situation and that was my problem.
There should be enough hose to shorten the pipe if required.
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: water leak
« Reply #2 on: 29 November 2008, 18:52:52 »
Dont rule out hbv as it leaks when you adjust the heater contols and when you turn the heater off the leak appears to stop and make the hbv seem ok, change it anyway then look for more hoses that have gone bad.
Jaguar XJ6
valet2002
Re: water leak
« Reply #3 on: 29 November 2008, 19:01:00 »
 thanks for that  will have anouther look at them
john
valet2002
Re: water leak
« Reply #4 on: 29 November 2008, 19:05:57 »
If it was the hbv valve wouldent it be leaking all the time them because I can get at the valve and there is no water leaking anywhere round it at all   :'(
john
Re: water leak
« Reply #5 on: 29 November 2008, 20:33:00 »
No  ;). It can depend on the water folw through it dependant on what heat is rquired in the car. Earlier this 'summer' I stopped mine from leaking by turning the A/C off untill I could get another valave. :y
valet2002
Re: water leak
« Reply #6 on: 29 November 2008, 20:42:00 »
ok thanks for that andy, do you know how much one of them hbv valves are then ?
so do you think if i got a new one then that poss might sort the problem out :y
john
Re: water leak
« Reply #7 on: 29 November 2008, 20:47:40 »
They're around £30. The HBV is a known item for water leaks. I've had my car for about 6 years & the valve I changed this summer was the 2nd I've changed.
valet2002
Re: water leak
« Reply #8 on: 29 November 2008, 20:57:48 »
 :) ok thanks 4 that one andy  :y It was just I couldent see any water leaking out of any of the HBV valve pipes thats why I was thinking that it might not be that  :) Thank you very much  :) cheers john...............
john
Page created in 0.029 seconds with 16 queries.
