Author Topic: I am new here so pls be patient. My Omega 2.2 CD i  (Read 1095 times)
Billy2000
« on: 29 November 2008, 11:14:03 »
I am new here so pls be patient. My Omega 2.2 CD is hard to start when really cold. I had a Vectra some years ago & had same problem so I replaced what I call the "heater plugs" Is the Omega the same & what is involved in changing them. My Omega is 2003. I hope someone can help & tell me the proper name as the weather is getting colder. Thanks.
Re: I am new here so pls be patient. My Omega 2.2 CD i
« Reply #1 on: 29 November 2008, 12:27:28 »
They are usually known as glow plugs.Available from halfords etc.
they just unscrew from the cylinder head,easy enough to do.
whereabouts do you live Billy,someone might be able to assist if you arent that confident.
Edit; might be an idea to check that power supply is ok to the glow plugs before changing them,could be a fuse/relay or similar.
« Last Edit: 29 November 2008, 12:43:17 by albitz »
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #2 on: 29 November 2008, 13:44:01 »
Hi billy, can you confirm that your car is
1= petrol
2=deisel
If it is deisel then the parts that you changed  on your vectra were indeed Glowplugs, but it might not be the problem on your car in this case, can you give some more info on the problems that you are experiencing, as i think there are reported problems with a small type of Hose or pipe that goes to the injectors.
If the car is petrol then that is again a compleatly different can of worms and the more info the better.  Welcome to the oof billy and with all the combined knowledge on here we will get your miggy running sweet as very soon.
Jaguar XJ6
Albatross
  • Bedford
  • An LSD & an S2000!
« Reply #3 on: 29 November 2008, 23:05:50 »
Update your profile with your location and car type / year / model.
If you feel up to it, add yourself to the OOF Map too. You'll be able to find local members on there too.
The link to the map is at the top of the page on the "Map" button or in my auto signature.
PM me or an admin for the password. I'm getting carted out Christmas shopping today, so an admin will give you a more immediate response.
