Author Topic: Omega 3.2 / 2.6 ECU's..  (Read 2611 times)
M-Tek Performance
  • Hull
« on: 07 November 2007, 09:50:18 »
Hi guys,
In my quest to hopefully be able to offer you the option of having your cars "chipped", I am wondering if it may be possible for someone with a 3.2 and a 2.6 Omega to look at the outside casing of their ecu and tell me what the numbers are on it?
Also, is it possible for some one to perhaps get a photograph of the inside of the ecu for the 3.2 / 2.6 please?
Thanks :y
Markjay
  • London
Re: Omega 3.2 / 2.6 ECU's..
« Reply #1 on: 07 November 2007, 10:19:52 »
Sorry, my phone cam isn't brilliant.... I'll try to copy the numbers by hand.
Alas, no more Omegas....
« Reply #2 on: 07 November 2007, 10:33:57 »
Get a picture of the white label.
The guts are surface mount items and its a flash based ECU (can be updated via tech2.)
M-Tek Performance
  • Hull
« Reply #3 on: 07 November 2007, 10:38:01 »
I dont think that the ecu map can replaced with tech 2?  At least that is what I have been told.
Im looking for anything that may be significant - it may be that ultimately the ecu can be flashed on the bench.
Thanks Markjay - i look forward to a second post :y
« Last Edit: 07 November 2007, 10:38:46 by M-Tek_Performance »
« Reply #4 on: 07 November 2007, 10:49:07 »
Well, you can update the software via tech2 and this software can also include a new map....
M-Tek Performance
  • Hull
« Reply #5 on: 07 November 2007, 11:17:28 »
Interesting - I had always been told this was impossible!
Markjay
  • London
« Reply #6 on: 07 November 2007, 14:06:20 »
On the metal casing:
253                     46062            III/2
254
GD ALS112(Cu)
On the white label:
183121   26SA7453   B10
0 261 206 490           AA
18315   0360
09 173 199      B01003
HTH
M-Tek Performance
  • Hull
« Reply #7 on: 07 November 2007, 15:39:20 »
Thanks Markjay :y
M-Tek Performance
  • Hull
« Reply #8 on: 07 November 2007, 19:52:55 »
Things are starting to look very promising ;)
Markjay
  • London
« Reply #9 on: 08 November 2007, 11:45:13 »
You can re-map my ECU remotely just by having these numbers off the sticker?  :o wow, I am impressed.  ;D
Martin_1962
« Reply #10 on: 08 November 2007, 12:54:03 »
I'm waiting anxiously!
M-Tek Performance
  • Hull
« Reply #11 on: 08 November 2007, 15:44:08 »
LOL
Nope, its because a company I am in talks with have actually got the software to do it already :y
