Author Topic: Heat up rate ??  (Read 2610 times)
amba
  • Medway towns
    • German V6
Heat up rate ??
« on: 01 December 2008, 13:26:16 »
From cold start this morning I travelled 4.0 miles before temp gauge started to move off bottom reading.Blower was giving luke warm air..once gauge started to move it then got upto 90 c fairly quickly and air from vents was noticeably warmer..only after I had been driving at steady 50mph for about 10mins did it go above 90 and then seemed to max out at 92.5 only going to 95 when stuck in morning traffic...the car by now was pushing out hot air from vents...I am not sure if I am becoming paranoid by this as changed thermostat in summer this year,but could a thermostat become "lazy"to open and close correctly?? I am convinced the temperature is not getting hot enough quick enough but don,t really want to get into  another thermostat replacement if this sounds consistant with others experiences.
Re: Heat up rate ??
« Reply #1 on: 01 December 2008, 13:31:16 »
 a simple test for thermostat is you immerse in boiling water  check the opening and let it cool down again check the opening... :y
« Last Edit: 01 December 2008, 15:19:30 by cem_devecioglu »
amba
  • Medway towns
    • German V6
Re: Heat up rate ??
« Reply #2 on: 01 December 2008, 13:43:01 »
Thanks for info cem,but if I got to the extent of taking it out I would just fit a new one again..more curious to see if others had similar heat-up rates as mine,or does it sound like stat number 2 is being "lazy" ?
RichardH
  • Ireland
Re: Heat up rate ??
« Reply #3 on: 01 December 2008, 14:06:32 »
My diesel is very slow to heat up in the mornings too.  Needle does not budge for for about 4 or 5 miles and I have lukewarm air from the vents.  Once the needle starts to rise though, the air gets warmer as you would expect.
Sounds like normal operation to me.
Re: Heat up rate ??
« Reply #4 on: 01 December 2008, 14:10:07 »
Sounds about right, mine is taking 3-4 miles on these cold mornings.
The cold air going in the inlet works well to cool the lump!
Re: Heat up rate ??
« Reply #5 on: 01 December 2008, 14:46:19 »
Best way to check is to start it from cold whilst feeling the top radiator hose. If it starts to warm up quickly and is significantly warm before the temperature gauge is up to normal running temperature, thermostat is toast. It should stay cold or only slightly warm until engine reaches normal temperature and then suddenly get very hot as the 'stat opens.
benbrunt
  • Oldham
Re: Heat up rate ??
« Reply #6 on: 01 December 2008, 14:55:03 »
Sounds on a par with mine, 2.5 V6 1999 model. It's been bloody freezing the past few days though!
<marquee>[img name=signat_img_resize]http://farm4.static.flickr.com/3208/3130811192_b672fbed66_m.jpg[/img]
Gas Guzzler, I love the stuff!
MickAP
  • South Derbyshire
  • Facelift 2.5TD Estate &quot;Chipped&quot; not anymore
Re: Heat up rate ??
« Reply #7 on: 01 December 2008, 15:03:24 »
It is colder in the mornings now.
I noticed it's takes longer in my other car to get warm and the gauge to move slower up to normal temp, I've just had a new stat in that.
I know the  stat in my TD needs replacing as the gauge hardly moves.
Mick
Re: Heat up rate ??
« Reply #8 on: 01 December 2008, 15:21:59 »
this test is mostly useful when you buy new!!  as some of them are not working properly  ;D
Re: Heat up rate ??
« Reply #9 on: 01 December 2008, 15:24:24 »
I will tell this to friends 8-)
Arrolman
  • Renfrew,Scotland
Re: Heat up rate ??
« Reply #10 on: 01 December 2008, 17:12:33 »
Hi,
Not meaning to hijack this thread but my TD gauge rarely moves off the bottom if i've got the heater on, if I put it off it will rise but as soon as heaters go back on its back to the bottom. Thermostat is it? :-/
Cheers,
Iain
Looking to win the lottery..........
megaomega123
Re: Heat up rate ??
« Reply #11 on: 01 December 2008, 19:23:56 »
I have definitely noticed a difference this week. Yesterday was -7C and I switch to gas at 85C and it took a good 6 miles before reaching temperature. My normal is about 3 miles before switch over.  :y
Re: Heat up rate ??
« Reply #12 on: 01 December 2008, 21:54:03 »
I will tell this to friends 8-)[/quote]
But does Turkey ever get cold enough?  :-/ :y
Re: Heat up rate ??
« Reply #13 on: 01 December 2008, 22:10:06 »
Ankara in January February sometimes reaches -10 in day time ,
and even exceeds -20 at night ..
And guess what , the next day mechanics become rich ;D :y
« Last Edit: 01 December 2008, 22:13:58 by cem_devecioglu »
Re: Heat up rate ??
« Reply #14 on: 01 December 2008, 23:23:11 »
My saloon takes about 2 miles then nice and warm - temp goes up to 92/93ēC (95ēC if in traffic jam)
The Estate seems to blow hot air quicker than the saloon, but same temp readings reached.
Hope that helps.  :y
« Last Edit: 01 December 2008, 23:23:38 by dbug »
