Author Topic: v6 no power and misfires  (Read 2155 times)
rocky daytona
« on: 01 December 2008, 18:33:58 »
hi everyone hope someone can help just brouight a 2003 2.6 v6 cd auto full service history car has developed a misfire and no power espescially under load have changed the plugs still the same will rev up inpark with slight misfire if you try to drive of it will go but you have to feather the throttle if you put your foot down it trys to stall once you get it moving you can drive it but with no real power gearbox appears to be changing up and down  put it on diagnostics it read oxygen senser and multiple misfires on numerous cylinders anyone got any ideas i read that the coil packs are troublesome please help if you can thanks
Welung666
Re: v6 no power and misfires
« Reply #1 on: 01 December 2008, 18:49:27 »
Any air leaks from the air box towards the plenum? Does the ICV need cleaning?
« Reply #2 on: 01 December 2008, 19:07:59 »
it seems to be a sensor problem but lambda sensor is not the cause
I think, lets see the other comments..
ps trying with the maf sensor unplugged will give more idea..
« Last Edit: 01 December 2008, 19:09:36 by cem_devecioglu »
rocky daytona
« Reply #3 on: 01 December 2008, 19:16:26 »
excuse my ignorance what is an icv  and do you think it worth changing the coil packs thanks
Big_Mart
  • CHESSINGTON
« Reply #4 on: 01 December 2008, 19:19:25 »
On the 2.6 it will be either the airflow meter or coil pack(s) :y
what was the exact fault code?
saab and vauxhall specialist
« Reply #5 on: 01 December 2008, 19:21:34 »
Idle Air Control Valve..
« Reply #6 on: 01 December 2008, 19:30:06 »
Hi, welcome to the forum.  :y
rocky daytona
« Reply #7 on: 01 December 2008, 19:35:37 »
not sure what the code was it just said oxygen senser then multiple misfires on different cylinders the garage said change the plugs as the oxygen senser may be showing because of the misfires the engine management light was taken of and hasnt come back on but it still has a misfire and no power you can rev it when stationary in park and overcome the misfires but it is still lumpy and lacking a sharp pickup
Big_Mart
  • CHESSINGTON
« Reply #8 on: 01 December 2008, 19:58:12 »
try disconnecting the air mass meter then start the car is the fault the same? :question
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #9 on: 03 December 2008, 15:46:47 »
Check very carefully around the cam covers for oil leaks first, then check for oil in the plug wells and then if all good check the Heater by pass valve at the rear of the plenium on the drivers side, for leaks or signs of past leakage, oil or water on the DIS pack will fuber the dis and this will cause the problems that you describe.
Jaguar XJ6
Essex_Andy
  • Have a guess?
« Reply #10 on: 03 December 2008, 15:53:06 »
Almost deffo ht leads.
With the recent cold snap and damp it will cause this problem.
Just, IMHO, wasted money on maf and dispack. (readings with multimeter across new dis pack and old dispack were the same)
New set of ht leads from Europarts and all good.
For £50-ish you can get a mobile diagnostic tuner to visit you and check all items.
Wish I had done that BEFORE buying a DIS pack and MAF
Diagnostic on all sensors if they are fine then 99.9% ht leads
« Last Edit: 03 December 2008, 16:06:15 by Essex_Andy »
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #11 on: 03 December 2008, 18:52:01 »
Andy this is a later car with coil packs.....
admin would it be worth merging this and the other thread together?
« Reply #12 on: 04 December 2008, 05:50:10 »
I would try disconnecting each coil pack individually to narrow it down rather than buy a whole set. :y
« Reply #13 on: 04 December 2008, 08:28:26 »
Welcome to OOF m8  :y
