Author Topic: The last straw ??  (Read 2614 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
The last straw ??
« on: 01 December 2008, 08:34:07 »
Hi all .... ive been having small niggly problems with this car lately and this morning the front ashtry has decided it doesnt want to close and seems to get stuck with about 1 cm left to go before it closes ..... this is not a big problem i know but with all i've had to do to this car its very nearly the last straw  >:( >:(  ... i couldnt see any way of removing it to try and repair it but i'll have a look at the maintenence section . Any tips on how it comes out and why i should not kick the sh** out this car greatly appreciated  :y
dene wakefield lad
  • wakefield yorkshire
  • my 1st love
Re: The last straw ??
« Reply #1 on: 01 December 2008, 08:39:03 »
open ashtray,screw in middle (top) and 1 either side :y
Proz
« Reply #2 on: 01 December 2008, 08:53:09 »
Ok thanks i will have a look .... is it possible to repair or will it be broken and more new parts needed .
RichardH
  • Ireland
« Reply #3 on: 01 December 2008, 08:54:57 »
Often with the ashtrays, a piece of small black plastic has broken off which prevents it from closing properly.  Take it out and have a look inside and you might find it.
Proz
« Reply #4 on: 01 December 2008, 09:28:56 »
Ok thank you .... it just seems to jam solid but i will see whats up when i take it out  :y
RichardH
  • Ireland
« Reply #5 on: 01 December 2008, 09:41:10 »
If it's just jamming solid, then make sure that it's set in it's runners correctly.  Had that probblem also on mine!
Proz
« Reply #6 on: 01 December 2008, 09:45:28 »
It gets to within a cm of closing then stops ... seems to be the drivers side thats more jammed than passenger side.... did you need to remove it to fix it .
Proz
« Reply #7 on: 01 December 2008, 09:47:27 »
I've decided im going to the boozer at lunch time with my brother and his pals so i wont be looking at it today .... will look tommorrow with that lovely hangover feeling  :D :D :D
RichardH
  • Ireland
« Reply #8 on: 01 December 2008, 11:14:20 »
Yep, I popped it out first.
Proz
« Reply #9 on: 05 December 2008, 18:19:55 »
Thanks for the help ... took it out and all fixed again . :y :y
Page created in 0.049 seconds with 16 queries.
