Author Topic: air con smelly  (Read 1781 times)
omegav6est
  • corsham wiltshire
air con smelly
« on: 29 November 2008, 17:20:41 »
 :-/hi all can any one tell me if when on hot the air con sucks in air from somewhere different from when its on cold.i have a smell of fumes coming into the car when the air con is on warm/hot  when i stop at lights or a junction etc that isnt there when the air con is on cold.and would not having a pollen filter fitted affect this as i discovered today that mine hasnt.no smell of fumes when driving along.also a question for a friend is it a straight forward swap to 3ltr cams into a 2.5.thanks
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: air con smelly
« Reply #1 on: 29 November 2008, 17:29:38 »
You need to buy an air con deodoriser that is discharged in the car with the air con  running on recirc and let the can empty, then vent the car by opening the doors. You a get it at most vx dealers or even half****s
Jaguar XJ6
omegav6est
  • corsham wiltshire
Re: air con smelly
« Reply #2 on: 29 November 2008, 19:34:06 »
i thought about that but the smell is not musty but rather more  petrol exhausty type of smell
Re: air con smelly
« Reply #3 on: 29 November 2008, 20:34:01 »
engine fumes getting in, with no pollen filter.
You could have
Blown cam cover seals.
Blown exhaust manifold gaskit.
Have seen posts along the lines of carbon monoxide(or dioxide what ever it is) poisoning. Beware.
Might not be that, i have no personal experience of it. Just seen its association on here. Hth
omegav6est
  • corsham wiltshire
Re: air con smelly
« Reply #4 on: 04 December 2008, 17:12:34 »
solved the problem....feel a bit of a plonker really,recently changed the oil but did not tighten the oil filler cap properly so it was spitting oil onto the manifold.tightened it up and hey presto the smell has gone.doh!!!
Re: air con smelly
« Reply #5 on: 05 December 2008, 00:32:48 »
Aha, i was'nt far off then. :-)
omegav6est
  • corsham wiltshire
Re: air con smelly
« Reply #6 on: 05 December 2008, 19:03:15 »
yes mate you were deffo in the right area,cant belive i missed sumit so obvious first time round.
Page created in 0.033 seconds with 16 queries.
