Author Topic: help needed plz  (Read 1947 times)
Shane mvsex
  • maidenhead
    • 3.0 pfl mv6 caravan
help needed plz
« on: 07 December 2008, 11:42:42 »
hi everyone iv not been on here for a wile.....
now i have problems with my v6.
the heater dosent blow anymore and dosent get hot.....
also the air con isnt working...
nothing has shown up on the trip screen apart from that..
the engine management stays on a bit longer when i start the engine??? any ideas of whats wrong ....
thanx :-?
migs and rc helicopters yeeeehaaaaaaa!
Www.omegaowners.com
Www.omegaownersnetwork.com
Shane mvsex
  • maidenhead
Re: help needed plz
« Reply #1 on: 07 December 2008, 12:01:35 »
its also running below normal temp dead on 90 in fact..
it usually runs around 97 to 100.....?
sometimes in traffic it warms it up and the heat works??
but soon as im moving again no heat grrrr ::)
Www.omegaowners.com
Re: help needed plz
« Reply #2 on: 07 December 2008, 12:18:48 »
Sounds like a vac leak.....at idle you ahev mega vac in the inlet, add throttle and the vac falls away.
The whole setup is vac operated so check the small vac pipes in the engine bay to satrt with.
Re: help needed plz
« Reply #3 on: 07 December 2008, 12:21:44 »
thanx :-?
Check the blower motor fuse, vac pipes to/from hbv and bulk head for the vent motors. Ac may have run out of gas with a leak. If the 4 knob pulley bottom right on the aux belt is not turning when ac is on and eco off then either no gas( use a specialist) or dodgy electrical connection to pump. If its turning and  no cold air in car then probably fan motor connection or fuse. No personal experience of these so get some other opinions.
May be worth a trip to Alton to see Kevin Wood with tech 2. Be quick though he only has it until the new year.
Try  http://www.omegaowners.com/forum/YaBB.pl?num=1189022687 for any engine codes for the eml. Only reads engine ecu remember. Hth
« Last Edit: 07 December 2008, 12:23:50 by chrisgixer »
Techno
  • Bedfordshire
Re: help needed plz
« Reply #4 on: 07 December 2008, 12:26:06 »
Sounds like you could have several problems here matey that could be either very simple to sort on nthe other hand a right pain ::)
There could be a few reasons why your heater isn't getting hot as you put it.
1.  If the fans not blowing as you say it could just be the fan isn't working not that the heater matrix isn't getting hot?
Check whether the matrix is getting hot, check the fuse for the fan and check the heater bypass valve.
2. Air con could just be that the gas has lost pressure the system has a pressure switch that shuts the system down when it drops below a certain pressure to stop damage.  It my just need gassing which is more than likely as the system is one of the better ones out there or something else has failed?
3. Don’t think these sort of problems will be picked up by the engine management system it should (I would have thought) pick up that the thermostat or temp sensor/s wasn't working as these are needed to correctly fuel the engine.  But you may need a Tech reader or do a pedal/paperclip test.
4. 97 - 100* I would say is on the high side and could well point to a failing thermostat, temp sensor, cooling fan or other cooling system component?
5. If the system works of sorts when the car's idling or in traffic could point to HBV, thermostat, any of the above mentioned or trapped air possibly?
Shane mvsex
  • maidenhead
Re: help needed plz
« Reply #5 on: 07 December 2008, 12:42:21 »
It has recently (3 months) been regassed and checked for leakage. And it has passed the check. I Guess im going to need someone who knows what they are doing to have a look Lol Any offers?? Lol ...
Www.omegaowners.com
Re: help needed plz
« Reply #6 on: 07 December 2008, 12:43:49 »
Lets get a few answers in place.
1) Can you hear the cabin fan blowing (turn it up full?).
2) Do you ever get heat?
3) If you change the setting for the air direction (screen/feet/face) do you hear the actuators moving and the air direction changes?
Shane mvsex
  • maidenhead
Re: help needed plz
« Reply #7 on: 07 December 2008, 13:15:53 »
1.... yes can hear it blowing...
2.. only wen stopped in traffic the engine temp goes up and it starts blowing with heat..
3... yes they all move fine ?
Www.omegaowners.com
Re: help needed plz
« Reply #8 on: 07 December 2008, 13:38:18 »
Right....in which case you most likely have a vac pipe leaking....
Shane mvsex
  • maidenhead
Re: help needed plz
« Reply #9 on: 07 December 2008, 13:42:36 »
ok how would i find out if one is leaking?
thanks for the help guys ;D
Www.omegaowners.com
Re: help needed plz
« Reply #10 on: 07 December 2008, 13:45:49 »
What you will find is a set of small plastic pipes running around the back of the engine bay.....some of these are related to gettinga v ac feed into the cabin to operate the controls.
The easiest way to find them is to look at the rear left of the engine bay where the heater pipes pass though the bulk head.....by these will be some pipes.
the left hand pips shoudl run over the rear of the engine bay to a vac reserviour above the pollen filter with the othe feed passing from the vac reservoir to a connection on the brake servo vac pipe.
Check these first adn look along the length of the pipe for chaffing etc.
Shane mvsex
  • maidenhead
Re: help needed plz
« Reply #11 on: 07 December 2008, 13:48:00 »
ok lol iv not got a clue what im looking for but il go and have a check now...
need the heat for my kids lol its cold.....
thanks m8
Www.omegaowners.com
Shane mvsex
  • maidenhead
Re: help needed plz
« Reply #12 on: 07 December 2008, 14:12:07 »
grrr i love my cars i just wish i knew what i was doing and looking for lol...
iv had a look and cant seem to see any lose pipes..
apart from one which is rite ontop of the cam cover at the back near the pollen filter .....
its not connected to anything ?
i started the engine and there is no blow or sucktion from that lose pipe? grr :y
Www.omegaowners.com
Re: help needed plz
« Reply #13 on: 07 December 2008, 14:33:56 »
That pipe is the auto box breather and shouldn't be connected to anything.
Does it still warm up as quickly as it used to? Just thinking it could be a Thermostat but seems to get hotter than I'd expect for a failed stat :-? :-?
Shane mvsex
  • maidenhead
Re: help needed plz
« Reply #14 on: 07 December 2008, 14:53:53 »
yeh the engine heats up ok soon after starting the revs go down to normal idle....
Www.omegaowners.com
