Author Topic: Engine Management light on...  (Read 2621 times)
damon80
  • Wigan
« on: 08 December 2008, 16:16:12 »
Hi Folks,
Got my new miggy, and chuffed with it so far  :y
But, driving into work today, the Engine Management light came on (not the one with the spanner in the car, the one that looks like an engine).
Anyway, I pedal-tested it, and it's come up with the following codes:
1530 (something to do with the air-con relay, but the air-con works fine?)
0420 (Catalyst System Efficiency Below Threshold (Bank 1) )
0430 (Catalyst System Efficiency Below Threshold (Bank 2) )
I've also noted that on the engine breather box (the black thing that says "Ecotec" on it on top of the engine), one of it's outlets that you connect the 4 hoses onto has been broken off at some point.  As you look at the top of it, from left-to-right, it's the 2nd one in from the left.  Is this likely to be contributing to this problem?
The car is a 2004 3.2 Manual.
Cheers
Danny
  • Wigan, Greater Manchester
Re: Engine Management light on...
« Reply #1 on: 08 December 2008, 16:29:21 »
the 4 little hoses iirc are breather hoses, thus giving you an air leak?
await confirmation, i know as much about cars as i do about the moon!
johnnycboy
  • Colchester
« Reply #2 on: 08 December 2008, 16:29:56 »
Hi Folks,
Cheers
could well be due to drawing more air into the system.  someone with more knowledge will be along soon
« Reply #3 on: 08 December 2008, 16:33:04 »
Though more than likely its a 2.6/3.2 with the dreaded pre-cat efficiency issue  :(
damon80
  • Wigan
« Reply #4 on: 08 December 2008, 16:36:28 »
Thanks for the prompt reply folks  :y
Why does this not fill me with confidence...  :o  :'(
What's involved in getting it sorted?
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #5 on: 08 December 2008, 16:39:07 »
I think you'll find it's a pretty common problem with the 3.0 and 3.2 V6's. Usually the pre-cats not being up to the job on these engines.
My EML has been on for months. I have it reset occassionally but it always comes back on again eventually. :(
« Reply #6 on: 08 December 2008, 16:41:27 »
Only the Motronic 3.1.1 cars (2.6 and 3.2) have precats.
I believe Albatross overcame it by moving the lamda sensors to be each side of the main cats, rather than precats.
damon80
  • Wigan
« Reply #7 on: 08 December 2008, 16:42:35 »
How do I go about resetting it?  Is it something that I can do by disconnecting the battery for an hour?  Or does the ECU store them until it's reset by Tech2?
bob.dent
  • Hertfordshire
« Reply #8 on: 08 December 2008, 16:44:14 »
Either a Tech2 or my garage have done it using a Bosch diagnostics system.
« Reply #9 on: 08 December 2008, 16:45:10 »
A cheap obdii code reader will reset it, but it will come back.
damon80
  • Wigan
« Reply #10 on: 08 December 2008, 16:50:50 »
Hmmmm...  >:(
Could it be that it's drawing in too much air because of the breather box being broken, so then it's throwing more petrol into the cylinders?
Or am I looking at having to move the lambda sensors (which I really don't like the sound of!  :o )
bob.dent
  • Hertfordshire
« Reply #11 on: 08 December 2008, 16:59:02 »
Hmmmm...  >:(
I've just got used to having the light on all the time now. Not sure what I'm going to do long term - probably will have to get the sensors moved eventually.
« Reply #12 on: 08 December 2008, 16:59:53 »
Hmmmm...  >:(
Fix the known issues, as that is always the best place to start.  But in this case, it is a well known issue :(
damon80
  • Wigan
« Reply #13 on: 08 December 2008, 17:05:30 »
Okidoki - thanks again for all your help folks  :y
I'll try sorting the breather box first, and see if that helps...  Not holding by breath, but it needs replacing anyway.
Now, anybody selling a breather box for a 3.2???  ;D
« Reply #14 on: 08 December 2008, 17:06:51 »
Same as all v6 I believe, nothing special about 3.2 one...
