Author Topic: problem with autobox  (Read 3497 times)
max23261
  • east ayrshire scotland
« on: 14 November 2008, 07:28:10 »
I came from the house yesterday and started the car only to see the gearbox warning light on. i tried to pull away but car would not move.i selected position 1 and off she went. manually through the gears ok but nothing if i select drive. the engine management light also stays on all the time. can anyone help please.
max :'(
MutantCav
  • Gainsborough
Re: problem with autobox
« Reply #1 on: 14 November 2008, 07:57:40 »
Top up the gearbox fluid...its probably run low and is killing your box or torque converter...I would do it before driving it again...
« Last Edit: 14 November 2008, 07:58:54 by ShieldOfSteel »
« Reply #2 on: 14 November 2008, 08:17:55 »
max :'(
You need the codes read. It could be low fluid level but it could also be any number of things, not neccesarily gearbox related.
« Reply #3 on: 14 November 2008, 08:21:47 »
Start by reading the engine codes as this you can do yourself
max23261
« Reply #4 on: 14 November 2008, 12:57:00 »
hi guys, fluid level ok. my mate is away with car to check fault codes so we will see when he gets back.
max23261
« Reply #5 on: 16 November 2008, 21:35:30 »
hi, had the codes read by local garage all ok. still having probs with gearbox. when i start car their is a rattling noise from under the bonnet that wasnt there before but the car drives ok and changes gear as it should.about 5-10 mins later it starts. the whole car shudders i put the car in neutral at the traffic lights but even in neutral the tick over shudders. it wont go forward in drive only in first. any ideas.
max :'(
max23261
« Reply #6 on: 16 November 2008, 21:36:48 »
forgot to mention their is no power when trying to accelerate and the car vibrates.
markey mark
  • SLady bitshorpe north lincs
« Reply #7 on: 16 November 2008, 22:21:46 »
check for oil in plugwells ! could be knackered coil pack ! have a spare from 2.2 if you need one fella ! :y
bighed
  • Shropshire
« Reply #8 on: 16 November 2008, 23:15:33 »
defo sounds like coil pack :y is there a misfire??
« Last Edit: 16 November 2008, 23:16:34 by bighed »
max23261
« Reply #9 on: 17 November 2008, 07:46:04 »
hi yes there is a misfire and when idleing you can here the engine miss.
max23261
« Reply #10 on: 17 November 2008, 07:55:23 »
thanks guys i will check the plugs first then the coil pack will get back to you asap.
thanks max.
bighed
  • Shropshire
« Reply #11 on: 17 November 2008, 17:48:07 »
i found out it was coil pack by removing leads on at a time from plugs. luckily enough it was the bottom left one that was playing up so no part removal to diagnose problem. coil pack removal is a bit of a pig tho  :y
max23261
« Reply #12 on: 25 November 2008, 12:45:42 »
hi guys,
well had the plugs and coil pack checked all ok no oil in wells bone dry.when i start the car first thing all ok will run for about 10 mins ok then the engine will start to missfire slightly.another few mins and it drives like a tractor no power everything shudders as if it is only going on 2-3 cylinders.if i am traffic lights i have to put auto in 1st to move. any ideas driving me mad.
max23261
« Reply #13 on: 25 November 2008, 12:47:16 »
forgot to say i am going down tomorrow to have the codes read again.incase they missed anything the first time.
« Reply #14 on: 25 November 2008, 15:49:19 »
Nearest oof tech 2 must be hotel21 might be worth a pm. Hes in Scotland, somewhere...?
