Author Topic: Some help needed ASAP  (Read 1963 times)
Arrolman
  • Renfrew,Scotland
« on: 08 December 2008, 18:15:39 »
Hi,
Whats the silver housing above the thermostat(The one above the one marked) On my 2.5TD, just had to strip the front off it as there was oil dripping out the bottom of it. Now I can't get the internal part to sit back in its housing. Any ideas?
Cheers,
Iain
« Last Edit: 08 December 2008, 18:16:28 by Arrolman »
Looking to win the lottery..........
Re: Some help needed ASAP
« Reply #1 on: 08 December 2008, 18:26:34 »
Vac pump.....?
Arrolman
  • Renfrew,Scotland
« Reply #2 on: 08 December 2008, 18:32:56 »
Hi,
Got it sorted, couldn't get the plastic lugs to sit on the ring on the middle, bit of shoggling sorted it. Now, how do I get to the thermostat ::), weekend job I think
Cheers,
Iain
« Reply #3 on: 08 December 2008, 18:50:48 »
the bit on end of cam is vac pump.  I may have a spare here if you fubar it.
The stat - once all shite removed, its just undo hose, and 3 10mm bolts.  TIS suggests transfer pipe has to come off, but I never did.
As I don't run a viscous, I could do my stat in around 20mins, most of that bleeding air from coolant - its one of the few good designs on tractor.
Arrolman
  • Renfrew,Scotland
« Reply #4 on: 08 December 2008, 19:02:59 »
Hi,
How much do you need to remove to get to the thermostat though? Looks like most of the stuff surrounding the fan and the fan, going to have to get new bolts for the rad cover if thats the case, mine are stripped >:(
Cheers,
Iain
« Reply #5 on: 08 December 2008, 19:33:09 »
Hi,
Cheers,
Iain
black 'turbo diesel' plastics, viscous fan and its plastic cowling.
Arrolman
  • Renfrew,Scotland
« Reply #6 on: 08 December 2008, 20:54:12 »
Hi,
Viscous fan easy to come off? Had all the 'Turbo Diesel' pipework off so only the fan it would seem needs to go
Cheers,
Iain
« Reply #7 on: 08 December 2008, 20:55:29 »
Hi,
Cheers,
Iain
Left hand thread. They come off easy, or they are a right bitch.
Arrolman
  • Renfrew,Scotland
« Reply #8 on: 08 December 2008, 21:07:34 »
Lol, don't like fans, had many a problem with ones on landrovers. Knowing my luck, will be a nightmare ;D
Cheers,
Iain
« Reply #9 on: 08 December 2008, 21:08:50 »
Cheers,
Iain
hence, my viscous stays in the garage...
Arrolman
  • Renfrew,Scotland
« Reply #10 on: 08 December 2008, 21:37:31 »
Will have a go tomorrow after work, need to get it changed, takes forever to heat up. Any chance that anyone knows what size the nut is?
Cheers,
Iain
« Reply #11 on: 08 December 2008, 21:40:19 »
Cheers,
Iain
for the viscous? I used adjustable, but think its 32mm
Arrolman
  • Renfrew,Scotland
« Reply #12 on: 08 December 2008, 21:42:46 »
Cheers very much, would be lost without the help on here!! :y
Iain
