Author Topic: 2.5 V6 Heater Matrix  (Read 1364 times)
Phil6157
« on: 09 December 2008, 16:05:48 »
Hi to all, I have just joined as I need help!
I have a 97 Omega, the car has just started to loose coolant, I can drive for about 10-15 miles before I need to top it up. But the inside of the car will not de-mist even on a hot day.
I think the problem is the Matrix so I have ordered a new one from e-bay
I do have the haynes manual, but is there an easy way of getting the matrix in and out.
Many Thanks
Phil......... :D
vauxfan2k
  • Western Isles
Re: 2.5 V6 Heater Matrix
« Reply #1 on: 09 December 2008, 18:17:34 »
easy way.... erm nope. im sure someone will be along soon that may know of a way, easy or not  ;)
Abiton
« Reply #2 on: 09 December 2008, 18:22:47 »
Not easy, but have a look at this thread, post #13 particularly.
http://www.omegaowners.com/forum/YaBB.pl?num=1219945946/0
The purists would say that you ought to take the dash out,  but I didn't fancy that, just don't love the car that much.  :-[
« Last Edit: 09 December 2008, 18:25:00 by Abiton »
keggy
« Reply #3 on: 09 December 2008, 19:50:07 »
you have to take dash out,not happy job did mine last year took hours and lots of swearing,but got prob with heaters again,cold .im doing a conversion at mo,to do away with the heater bypass valve,sowatch my post,keggy for results,and goodluck ,kev
andyc
  • Norfolk
« Reply #4 on: 09 December 2008, 22:04:17 »
Yes dash out, stripped one out the other week and it was a "bit of a job" ::)
Andy
Thetford. Norfolk
« Reply #5 on: 10 December 2008, 08:57:08 »
Hang on a minute....we dont dive into assumptions such as heater matrix failed until a proper diagnosis has happened.
A number of things can cause steaming....blocked rear cabin vents, old pollen filter, recirc activated, blcoked scuttle drain.....all of which are far more common than a failed heater matrix.
In addition to this, there are other things that can cause water loss.
My first question would be, is the inside of the windscreen smeary?
When antifreeze gets on glass its very smeary and easy to spot!
