Pages: 1 [2] 3  All   Go Down
Author Topic: Lumpy till warmed up ?  (Read 6706 times)
Techno
  • Bedfordshire
Re: Lumpy till warmed up ?
« Reply #15 on: 27 November 2008, 15:41:58 »
To do what I list takes no more than an hour less if you know what you are doing.  All parts are very easliy removed and accessible with nothing more that simple tools required.
« Last Edit: 27 November 2008, 15:43:04 by Techno1 »
amba
  • Medway towns
    • German V6
« Reply #16 on: 27 November 2008, 15:51:23 »
Quite accept that they are simple jobs to do and time is no problem..just was unsure how you clean a MAF meter.?
Techno
  • Bedfordshire
« Reply #17 on: 27 November 2008, 15:57:24 »
It's easy they get covered in road crud and alike, all I did was use a little brake cleaner and a small bursh ;)
amba
  • Medway towns
    • German V6
« Reply #18 on: 27 November 2008, 16:22:02 »
Thought the oil coating on the inside would get messed up.
Techno
  • Bedfordshire
« Reply #19 on: 27 November 2008, 16:32:00 »
Hang on are we taking about the same part/s here
Air flow meter, intake air temp sensor are located in the induction system just after the air filter box there should be no oil on them to start with.
Idle speed adjuster valve is located front left hand side of the plenum chamber this is just a rotary valve in a chamber the slave block gets covered in carbon/oil deposits and blocks/sticks thus causing poor idling or stalling.
By flushing with carb/brake cleaner these deposits are removed it doesn't need oil to operate as it's powered by an electric motor.
amba
  • Medway towns
    • German V6
« Reply #20 on: 27 November 2008, 16:37:23 »
Think we are getting a bit at cross purposes..the airflow meter(or MAF)is located on the large pipe running from the air filter.It has a oil coated blade arrangement inside which I thought should not be cleaned as the surface is oil coated and is regulated by warm air flowing across it before it goes through the throttle bodies into the plenum..is this the bit you cleaned with a brush and brake cleaner?
Techno
  • Bedfordshire
« Reply #21 on: 27 November 2008, 17:32:38 »
Yes but I don't think it's oil coated as more like some kind of polyurethane material it's certainly wont/it's affected by spaying with carb cleaner and a gentle brushing to remove stubborn road grime. As with all induction systems there is always some level of fuel vapour present so anything placed within the system will be solvent resistant.
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #22 on: 27 November 2008, 19:15:45 »
Hello,Is it possible your problem could be a breaking down D.I.S unit ?Regards,Cliff. :-/
amba
  • Medway towns
    • German V6
« Reply #23 on: 27 November 2008, 21:56:26 »
Not dis as fitted new about 2 months ago along with new leads/plugs and hbv,so nothing in that area .Am sure all leads and cables went back correctly as is running perfect,its just this niggle before it warms up.
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #24 on: 27 November 2008, 22:00:45 »
MDTM maintains the MAF should only be cleaned with keyboard foam cleaner, carb cleaner etc can damage the element.
« Reply #25 on: 28 November 2008, 10:39:56 »
Hold on aren't we going yet a little too deep here?
I had the same problem I did the following: -
1. Clean the Air flow meter, intake air temp sensor and idle speed adjuster valve.
2. Replace/clean air filter.
Worked for me  :).
if mentioned parts are dirty why it will work normal when the engine reaches 90 C..
Technically there can be many reasons..and one of the reasons can be an expensive fix..before spending unnecessary money it will be very practical to see the engines condition by compression check..
if cylinder rings are worn or there is a leak from valves whatever you
change wont help.. :-/
Techno
  • Bedfordshire
« Reply #26 on: 28 November 2008, 12:16:47 »
The issue is lumpy idle until warm, a loss of compression due to rings or valves will not go away when the engine warms up and there will be a loss of power and drivability.  If the rings are worn you will also get oil loss and smoke due to burning, crankcase overpressure leading to areas of flooding in the emission control system.  If the valves where leaking again a loss of power would be very evident and before long they will burn out with a drastic loss power, other common symptoms will be difficulty in starting and an ever increasing drop in fuel economy.
My understanding of why cleaning the parts I mentioned works (providing there are NO other symptoms other than just lumpy idle) is: -
1. The Air flow meter does just that measure air flow if it's dirty it cant so it thinks it's flowing faster/slower than it is, thus the ECU increases/decreases the mixture slightly giving you either too rich (over choked) or to lean (weak) both will give you a lumpy idle.
2. Intake air temp sensor if this to is dirty it will under/over read the real temperature giving the same result.
3. Idle speed adjuster valve if this is dirty/gummed up it will not respond correctly to ECU signals again giving you a lumpy idle
I'm not an expert and I my be way off with my thinking but in my humble opinion I believe that providing there are no other issues then these are the first port of call.
« Reply #27 on: 28 November 2008, 12:28:46 »
A slightly worn rings can do that..Thats the point you are missing..
I remember I read some technical papers about that on the net..
Of course cleaning those will help..But dont expect 100% efficiency from an old engine and old sensors.. I can guarantee a 98 model car regardless of brand model unless stayed in garage for a long period will be worn a bit..
« Last Edit: 28 November 2008, 12:31:24 by cem_devecioglu »
« Reply #28 on: 28 November 2008, 12:33:04 »
here is an interesting page..
http://www.popularmechanics.com/how_to_central/automotive/1272271.html?page=2
"An engine with high mileage that's tired and worn out may not pull a healthy vacuum of 18 to 20 in. Hg at idle (closed throttle plate) anymore. That means the MAP sensor will always read the engine as under load (low vacuum) and--just doing its job--inform the powertrain computer to add more fuel. When the oxygen sensor picks up the rich mixture in the exhaust stream, it will call for a leaner mixture. Common strategy is to open the idle air-bypass valve to let some more air in. But an engine that's just on the borderline of wheezing may intermittently "loosen up," leading to a roller coaster idle. It may have trouble breathing when cold, but once warm-with expanded piston rings, gaskets and the like--show a perfectly healthy intake vacuum. "
« Last Edit: 28 November 2008, 12:34:19 by cem_devecioglu »
amba
  • Medway towns
    • German V6
« Reply #29 on: 28 November 2008, 12:33:29 »
Thanks for all your input and advise,guys.
I will go the least difficult and most cost effective route first and will do the cleaning atc as suggested by Techno.The car is due a full brake check and other bits in the new year and as this can be done indoors and under cover I will suggest to my mechanic that we undertake a compression test just to see what results are from each cylinder as would be usefull info aswell.
The problem is evident every morning when car is started from cold and this was my thought pattern regarding the temp sender as I understand that this sends a signal to ecu for fueling until the car warms up and then the lambas take over.
This morning the car started first turn as always,but temp took about 5mins in slow traffic before gauge started to register and all the time tickover was erratic with needle moving from 500-750+ and engine feeling very uneven.When the gauge started to move upto 90 and beyond this completely went and the engine ticks over very smoothly,with it now registering mid way on temp gauge (95) and silky smooth tickover.There is no oil loss or usage and the performance from the engine is so good that I have no hesitation in keeping a wonderfull 10 year old car,and relying on it daily for my 100 mile a day job.
The problem is not major,merely of mild concern (well atleast at the moment..I hope).
Pages: 1 [2] 3  All   Go Up
