Pages: 1 2 [3]  All   Go Down
Author Topic: Lumpy till warmed up ?  (Read 6704 times)
Re: Lumpy till warmed up ?
« Reply #30 on: 28 November 2008, 12:37:02 »
Thanks for all your input and advise,guys.
I will go the least difficult and most cost effective route first and will do the cleaning atc as suggested by Techno.The car is due a full brake check and other bits in the new year and as this can be done indoors and under cover I will suggest to my mechanic that we undertake a compression test just to see what results are from each cylinder as would be usefull info aswell.
The problem is evident every morning when car is started from cold and this was my thought pattern regarding the temp sender as I understand that this sends a signal to ecu for fueling until the car warms up and then the lambas take over.
This morning the car started first turn as always,but temp took about 5mins in slow traffic before gauge started to register and all the time tickover was erratic with needle moving from 500-750+ and engine feeling very uneven.When the gauge started to move upto 90 and beyond this completely went and the engine ticks over very smoothly,with it now registering mid way on temp gauge (95) and silky smooth tickover.There is no oil loss or usage and the performance from the engine is so good that I have no hesitation in keeping a wonderfull 10 year old car,and relying on it daily for my 100 mile a day job.
The problem is not major,merely of mild concern (well atleast at the moment..I hope).
Thermostat and Coolant temperature sensor needs checking..
and another test..try disconnecting the secondary air injection pump..
« Last Edit: 28 November 2008, 13:16:54 by cem_devecioglu »
omegalad
« Reply #31 on: 10 December 2008, 04:18:01 »
ive noticed something in my car i have previous post about this though with the bad judder in my acceleration power loss.
she isnt fixed yet
when the car is cold shes lumpy till warm right?
BUT when i put on the fan/heater on full blast when the engine is cold she gets REALLY rough then i switch it off goes lil smoother. but then when the engine warms up its like normal.
what this mean??
wonder if this is the cause somewhere like a leak? engine airflow not running right etc.??
MarkG
  • Northwich, Cheshire
  • "An Omega? Been a while since I saw one of those!"
    • 2000 CD 2.5 V6
« Reply #32 on: 10 December 2008, 16:13:20 »
If you have an air leak, then you should be able to hear it if you stick your head under the bonnet while the engine is running. wiggle anything that moves to see if it changes pitch. Look in particular at the brake servo vac pipe where it rubs against the AC fitting on passenger side (you would also notice lack of braking power it this is holed) and the narrow bore pipes around the back of the engine drivers side.
Consider also ignition leads starting to break down or worn out plugs. When were they last changed?
Pages: 1 2 [3]  All   Go Up
