Author Topic: headlight washers  (Read 787 times)
Richie London
  • heathrow
headlight washers
« on: 10 December 2008, 20:12:52 »
there is a piece of pipe the washer is attached to, can it be replaced mine is split at the end?? how easy to change over, im getting a massive gush  of  water spray when i use the washer ??
« Last Edit: 10 December 2008, 20:13:34 by richierich »
MutantCav
  • Gainsborough
Re: headlight washers
« Reply #1 on: 10 December 2008, 20:43:25 »
Yes mate easy enough to change...got a replacement here if you want one cheap :) Washer jet plugs into the unit your referring to which is attached to the underside of the headlight...remove headlight, change over and put headlight back :)
« Last Edit: 10 December 2008, 20:45:05 by ShieldOfSteel »
