Author Topic: Washer Bottle Query  (Read 3210 times)
HerefordElite
  • Hereford
  • Welcome to the Shire
Re: Washer Bottle Query
« Reply #15 on: 10 December 2008, 22:03:20 »
Or if you just need to get the pumps out then there is no need to take the bumper off. If the washer bottle is leaking from the pumps it may be useful to remove the bumper to empty the bottle totally then remove both of the pumps clean them up then use some hylomar sealant to stop the leak. I had the same problem with mine and done this...... Now no leaking washer bottle.
Paul :y
Cheers guys, is hylomar sealant easily available?
I used Fernox 'LS-X' from my local plumbing merchant :y
Edit:
(it's a jointing compound and leak sealer ;))
« Last Edit: 10 December 2008, 22:04:37 by herefordelite »
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #16 on: 11 December 2008, 00:14:50 »
If that's the one that cures when wet - it's a cracking bit of kit
HerefordElite
  • Hereford
« Reply #17 on: 11 December 2008, 00:39:51 »
yep says "min of 1 hour to set...spraying with water speeds curing" :y
