Author Topic: Washer Bottle Query  (Read 3126 times)
elite3.0v6tourer
  • worcestershire
Washer Bottle Query
« on: 09 December 2008, 15:40:41 »
Need to replace my front washer bottle,will 1 from a 96 elite fit a 99 elite, i think they would be the same but thought i would ask first :-?
Re: Washer Bottle Query
« Reply #1 on: 09 December 2008, 15:55:08 »
Yep....will fit fine
elite3.0v6tourer
  • worcestershire
« Reply #2 on: 09 December 2008, 16:16:25 »
Cheers mate just spoken to vaux and they confirm aswell :)
benbrunt
  • Oldham
« Reply #3 on: 09 December 2008, 17:42:12 »
Mine's leaking like a beehatch, is it an easy job to take it out and resit the pump on the seals? Anyone done it, how long would you recon it should take, maybe a job for boxing day in my parents garage
<marquee>[img name=signat_img_resize]http://farm4.static.flickr.com/3208/3130811192_b672fbed66_m.jpg[/img]
Gas Guzzler, I love the stuff!
markey mark
  • SLady bitshorpe north lincs
« Reply #4 on: 09 December 2008, 17:44:25 »
just take the grill of and you can see pumps !!  :y
so three screws and your in mabye half am hour to take pumps out and clean the filter on the bottom and refit !  :y
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #5 on: 09 December 2008, 19:01:52 »
but if you want to take the bottle out completely it's a bumper off job as it's screwed to the inside metal reinforcing bar :-/
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #6 on: 09 December 2008, 19:40:29 »
This is the recommended approach from Haynes but it is not required. I've removed the bottle on a '99 mini-facelift and an '03 facelift without removing the bumper. From memory, It is just a case of undoing the 3 screws and manipulating the bottle out
benbrunt
  • Oldham
« Reply #7 on: 09 December 2008, 21:09:37 »
Cheers, all being well I'll get it done before I freeze on boxing day!
HerefordElite
  • Hereford
« Reply #8 on: 09 December 2008, 21:24:57 »
how do you get at the screws? from inside the engine bay??? :-?
« Last Edit: 09 December 2008, 21:25:10 by herefordelite »
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #9 on: 09 December 2008, 23:34:32 »
no, enough room from behind the bumper to get at them - you have to feel for them, rather than see them
VX1
  • Reading, Berkshire
« Reply #10 on: 10 December 2008, 14:28:43 »
Or if you just need to get the pumps out then there is no need to take the bumper off. If the washer bottle is leaking from the pumps it may be useful to remove the bumper to empty the bottle totally then remove both of the pumps clean them up then use some hylomar sealant to stop the leak. I had the same problem with mine and done this...... Now no leaking washer bottle.
Paul :y
Vx Trade club card holder
Halfords trade card holder
benbrunt
  • Oldham
« Reply #11 on: 10 December 2008, 19:41:51 »
Paul :y
Cheers guys, is hylomar sealant easily available?
VX1
« Reply #12 on: 10 December 2008, 20:34:00 »
Yes it is. You should be able to get from any factor or halfrauds.
Paul  :y
benbrunt
  • Oldham
« Reply #13 on: 10 December 2008, 20:36:11 »
Paul  :y
I look forward to sticking my fingers together with it already :-X
Diy is not my strongest point
VX1
« Reply #14 on: 10 December 2008, 20:43:59 »
At least buying some sealant is less expensive than buying a new washer bottle but when you do come to put the pump seals back in make sure they are clean and dry otherwise it won't seal.
Paul  :y
