Author Topic: Sump gasket  (Read 1384 times)
Miggy24
  • Exeter,Devon
Sump gasket
« on: 11 December 2008, 14:44:49 »
Hi all i have a 2.0 8v engine in my omega i think its the old carlton engine.Anyway can anyone tell me what engine it is so i can order one from ebay.many thanks :y
Wolf
Re: Sump gasket
« Reply #1 on: 11 December 2008, 15:15:29 »
Hi!
The enginecode is X20SE.
greetz
Wolf
Miggy24
  • Exeter,Devon
Re: Sump gasket
« Reply #2 on: 11 December 2008, 16:05:14 »
Ok thanks for that mate.Is taking the sump off and replacing the gasket an easy job.I had alook under there quickly and just looks like loads of 10mm bolt.Do i just undo them and it comes off and also do i need to use a sealer for the gaskets if so whats the best to use
« Last Edit: 11 December 2008, 16:07:53 by devonboy2008 »
vauxfan2k
  • Western Isles
Re: Sump gasket
« Reply #3 on: 11 December 2008, 20:04:58 »
On my 1992 2.0v carlton cdi we had to undo the engine mountings and raise the engine slightly to gove enough room to get the sump completely off (due to oil pick up pipe) made it easier to clean the mating surfaces and apply the new gasket.
cheers :y
« Last Edit: 11 December 2008, 20:05:14 by Vauxfan2k »
unlucky alf
  • worksop, notts
Re: Sump gasket
« Reply #4 on: 12 December 2008, 00:18:37 »
you might want to use something like blue hylomar on the gasket, not only does it aid sealing but it holds it in place, nothing worse than getting under there & the gasket keeps moving about ;D
Miggy24
  • Exeter,Devon
Re: Sump gasket
« Reply #5 on: 13 December 2008, 13:40:56 »
Had alook at the sump 2day and it looks easy to take off and dont need to undo anything to get to it :y
