Author Topic: What's the difference between 2.5 and 3.0????  (Read 4407 times)
JueV6
  • Kent
« on: 12 December 2008, 21:17:54 »
Apart from 500cc's
After killing my 3.0, for the sake of a starter motor, (which I had spare) I took out the LPG kit.
I don't wanna take the Super mig off the road at the moment so thought, ok do it bit by bit.
So today i decided to swap the inlet manifold and plenom over.
Off with the 2.5 plenom and inlet and on with the 3.0 inlet. then the plenom ohh poo the hose from the coolant bridge was too short. off with the plenom and the skuttle panel. 3.0 pipe fitted, jobs a goodun', NOT.
cruise cable is too short, so changed that to 3.0 and then the throttle cable. OK now see what happens.
Turn the key and 3000 revs
unplug the ICV and 700 revs, Change the ICV and it was the same.
unplug it and 700 revs.
Off to pick Helen,  from town and guess what, IT WON'T CHANGE GEAR. 1st the 2nd thats it.
Spoke to TB and he couldn't throw any light on the problem.
OK put the 2.5 Plenom back on together withe the 2.5 cruise and throttle cables. boxed it all back together and it's like nothing had been changed. she runs like a dream.
Tank / Filler and Pipework tomorrow
SO..... whats the difference between the 2.5 and 3.0 apart from the physical size of the plenom and the kick down on the throttle cable.
TIA
Julian
PS. I didn't use the 2.5 plenom to start with because the 3.0 one already has the vacuum pipes drilled and tapped with the nozzles.
« Last Edit: 12 December 2008, 21:20:10 by Juedu2 »
iainb
  • West Midlands
Re: What's the difference between 2.5 and 3.0????
« Reply #1 on: 12 December 2008, 21:55:41 »
The ECU map is totaly different.
There was a guy in Germany selling chips for 3.0l engines in the 2.5l cars, which meant you didnt have to change the ecu.
As I understand it if you put a 3l engine into a 2.5l it will run lean and burn out
« Reply #2 on: 12 December 2008, 22:18:33 »
Apart from 500cc's
TIA
Julian
about 40bhp ;D
As said earlier, wondering if tps reads different...  ...thinking about it all evening, thats all I could still come up with.
The smaller plenum is probably better for 2.5 anyway
« Reply #3 on: 12 December 2008, 22:19:40 »
Not sure the programmed map is different...
damon80
  • Wigan
« Reply #4 on: 12 December 2008, 23:36:35 »
Would you not be able to switch ECU's to test, or would it be too much of a ball-ache?  Because I'd also assume that you'd need to switch the immobiliser transponder over from the key too...  :-/
markey mark
  • SLady bitshorpe north lincs
« Reply #5 on: 12 December 2008, 23:47:50 »
funny this jue i have the same problem on the 2.5 i have fitted a 3.0 with ext plenum !!  :-? :-?
MutantCav
  • Gainsborough
« Reply #6 on: 13 December 2008, 11:29:31 »
As I understand it the longer plenum (which is only fitted to 3.0 engines so presumably there is a reason) gives better airflow and higher torque in lower gears...the lower and upper inlets on the 3.0 has bigger holes so presumably so does the plenum as it sits on top of them...cant shed any light on the why for this but hopefully this info might help somehow??
« Reply #7 on: 13 December 2008, 11:47:27 »
Assuming there were no air leaks with either setup I'm with TB. There must be a difference in the throttle position sensor. This would give a poor engine load reading which is why the autobox was playing up, at a guess. :-/
Whilst there are clearly differences in plenum volume and port diameter these would not affect the engine so fundamentally IMO.
MutantCav
  • Gainsborough
« Reply #8 on: 13 December 2008, 12:06:51 »
Just a thought (that came to mind when talking about TPS) is the accelerator cable shorter on the 2.5 thus struggling to reach properly to the position on the longer plenum affecting the pull on the TPS??
Could adjusting the little clip help sort this issue?
« Reply #9 on: 13 December 2008, 12:12:26 »
Hmm. that's a point. Could be something odd going on with the kickdown switch too, perhaps, hence the odd gearbox behaviour. :-/
« Reply #10 on: 13 December 2008, 12:56:43 »
I know JueV6 swapped the throttle cable etc over as well.
markey mark
« Reply #11 on: 13 December 2008, 13:41:45 »
im just about to fit 2.5 tps will let you know shortly ! :y
JueV6
  • Kent
« Reply #12 on: 13 December 2008, 14:01:52 »
The car is no sitting with.
X25XE
complete.
But has the X30XE inlet manifold / injectors / Fuel Rail. and any other bits that are connected to the Manifold.
Everything else was changed BACK to the 2.5
Runs perfect
Injectors have the same part numbers and the only difference is the port diameter as far as I can see.
Even The Boy is at a loss.
« Reply #13 on: 13 December 2008, 14:39:35 »
epc implies the tps (in fact the entire throttle body) is identical between 2.5 and 3.0, so I'm back to the theory of massive airleak...
Essex_Andy
  • Have a guess?
« Reply #14 on: 13 December 2008, 14:49:01 »
I fitted a 3.0 throttle body on to my 2.5 plenum.
I had to fit the 2.5 tps onto the 3.0 body.
Different plug on the 2.5 loom
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
