Author Topic: Wishbone bushes  (Read 5199 times)
Matchless
  • Nottingham
    • A white van
Re: Wishbone bushes
« Reply #15 on: 09 December 2008, 22:37:56 »
If MDTM has fixed his press, I believe he would recommend some Merle bushes pressed in to old wishbones.
We put genuine Vx bushes in mine back in the summer, before the press got destroyed at Newent :o
Thats a little job for Xmas week.....need some welding therapy  :y
Did something get damaged at Newent - I can't remember that.... :-[ :-[ :-[ :-[
Bob - I went the Merle route and they are fine.  Iggy21uk sourced them (importer in Leeds if I recall) - if you do a search I'm sure you will find the thread.
When I was at WIM Tony said that the last one they did (with Sealey 10T press) was a real dog though - maybe why they don't do it any longer.   I suspect yours will be fine - it was my old ones that did for Mark's press.
Cheers
Ian
Don't worry ians - I blame it on Mr DTM's substandard welding...
[size=14]TB waits for Mr DTM to blame Matchless....[/size]
Matchless blames the cheap wire feed mechanism on his Migmate and wonders if he will ever see his bottle jack again
gwa
  • Peterborough
  • Ginger With Attitude
Re: Wishbone bushes
« Reply #16 on: 10 December 2008, 07:49:06 »
Most garages will have a press.  My difficult one cost a tenner.
So as a scenario: If I get 2 wishbones of an OOF scraper or fleabay, buy the new bushes and take it all to local garage they'll re-bush the wishbones for a small fee, is that correct?
If it ain't fun, it ain't worth doin
Re: Wishbone bushes
« Reply #17 on: 10 December 2008, 09:12:38 »
Well, in theory yes. Trouble is you need drifts that fit the bushes. I had imagined using a larger socket or some similar item. But when the bushes arrived it was clear that would not work for 2 reasons.
1. the outside edge of the bush is 1mill or so wide iirc so the drift has to be a fraction smaller than than the hole in the wishbone but big enough to not slip into the centre of the bush and rip the rubber.
2 the centre "spacer"set into the rubber sits proud of the outside edge obviously so the drift needs needs to have a suitable hole to allow for this or you risk forceing the centre spacer out of the rubber and again, ripping the rubber.
 Or something like that, ive not used correct drifts so cant tell you how they fit. But i imagine something could be turned on a lathe to give the right fit. Hth.
PxMetro
  • Stamford
  • Maryland Cookies are brilliant for dunking
    • 3.2 MV6 Estate
Re: Wishbone bushes
« Reply #18 on: 10 December 2008, 13:19:23 »
For what it's worth, you mite just as well buy some new, ready assembly wishbones and fit them.
It's a lot of extra hastle to remove the old items, sort out getting the new bushes fitted, before taking them back and fitting to the car.
I fitted some pattern parts about a year ago, and they work perfectly fine. Just be carefull with the linkage for the HID light sensor thingy, as the ball joint can be dry and rusty.
You will have to get the steering geometry checked and adjusted afterwards though, if you are to avoid some interesting handling characteristics.
Re: Wishbone bushes
« Reply #19 on: 10 December 2008, 19:28:56 »
The idea is to fit better bushes than the standard vx items. If all bushes where equal and all wishbones where only a phew quid more than a set of bushes then obviously you would not bother pressing.
 Bear in mind the cheapest possible wishbones with oe bushes  are 120 a pair. By pressing you own you can have better bushes for 39. The issue wim had is they cant do it quick enough to make it cheaper than buying a new set. Ie 2 hours labour for them is
140 or something like...as Tony(wim) said, not cost effective for the customer.
gwa
  • Peterborough
Re: Wishbone bushes
« Reply #20 on: 10 December 2008, 21:34:11 »
Thanks guys, thats really useful info.  :) :) :) :) :) :) :)
Re: Wishbone bushes
« Reply #21 on: 11 December 2008, 10:09:55 »
Merle bushes fitted to mine, as was recommended by a thread on here, iggy 21 on here knows the contact details. Wish i could find that thread, i want ask Merle if there are slightly harder bushes than the ones i have.
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
Re: Wishbone bushes
« Reply #22 on: 11 December 2008, 11:44:04 »
Have a look on the Meyle on the website may find HD version ?
http://www.wulfgaertner.com/html/index.php
The bushes I got from the supplier in Leeds was not a stock item
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
gwa
  • Peterborough
Re: Wishbone bushes
« Reply #23 on: 12 December 2008, 11:17:15 »
Where do these come from? :y
Re: Wishbone bushes
« Reply #24 on: 12 December 2008, 11:42:31 »
gwa
  • Peterborough
Re: Wishbone bushes
« Reply #25 on: 12 December 2008, 16:00:02 »
http://www.autovaux.co.uk/LoadPortal.aspx?tabid=3
And you want the Lemforder ones
Fantastic  :y Rang up and they are on there way, £60.20 inc VAT and delivery each. Although I asked for Sat AM @ £18. He asked who recommended and I told him you did, so make yourself known next time. Thanks again Mark  :y :y :-*
« Last Edit: 12 December 2008, 16:00:23 by gwa »
gwa
  • Peterborough
Re: Wishbone bushes
« Reply #26 on: 13 December 2008, 20:23:29 »
Bl00dy fantastic. Marks DTM recommendation of
The wishbones duly arrived around 08:45, I went over to Serek's (an OOF Member) place around 15:45. After a coffee and a chat we started around 15:30 and by 17:30 all done and dusted, including putting the tools away and cleaning up.
Many many thanks to you all  :y :y :y :y :y :y :y  :-*
