Author Topic: Headlight Adjustment  (Read 952 times)
lou
  • Romford
  • Always expect the unexpected
« on: 14 December 2008, 17:34:29 »
Hi all, I am trying to raise the beam of driver's headlight by adjusting to the 2 screws (Remenbering the No of turns) on top of the headlight, but nothing is changing. the long screws also seem to turn some white button at the back of the light. Any ideas...help much appreciated. (2.5 V6 mini facelift) :)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: Headlight Adjustment
« Reply #1 on: 14 December 2008, 18:22:11 »
Sound to me like an adjuster inside the headlamps has disintegrated (a very common problem for which the only real remedy is a new headlamp) :(
MutantCav
  • Gainsborough
« Reply #2 on: 14 December 2008, 20:17:52 »
It takes a lot of turns to go a very short distance...but may as said be broken adjuster...its common
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #3 on: 14 December 2008, 20:37:10 »
very fine pitch thread to adjust - i used a hex drive in a battery drill when i had to adjust mine from scratch ;)
