Author Topic: Hot and cold  (Read 1280 times)
dlan
Hot and cold
« on: 08 December 2008, 12:22:59 »
Have a 2003 CD auto 4 cyl. with some interesting symptoms. I am getting what seems to be AC out of the driver's side while the climate control is set at 28. Passenger side gets hot easily. I read the posts concerning the HBV, but I'm not sure thats the problem...
Any input mates?
dlan
Re: Hot and cold
« Reply #1 on: 08 December 2008, 12:28:20 »
Also no visible leaks whatsoever.
Re: Hot and cold
« Reply #2 on: 08 December 2008, 12:42:17 »
Most likely the climate servo motor actuator arm has popped off.....have a little look in the maintenance guide section for details
dlan
Re: Hot and cold
« Reply #3 on: 08 December 2008, 13:03:51 »
Ill take a look after work, thanks for the direction.
chrisl_1960
  • cambs
  • why didnt I get a V6
Re: Hot and cold
« Reply #4 on: 13 December 2008, 12:24:19 »
hello, have you had any joy fixing this? I have a 2000 2.2 CD with identical problem
abdin
  • Jordan - Amman
Re: Hot and cold
« Reply #5 on: 13 December 2008, 19:17:18 »
Hello guys
to avoid such a case make sure to press the eco botton on climate control panel instead of auto botton this will stop a/c compressor and you'll get hot air on both sides
abdin
chrisl_1960
  • cambs
Re: Hot and cold
« Reply #6 on: 15 December 2008, 20:40:48 »
hello abdin, thanks for the info, tried it today but alas, still cold air coming from the vents on the drivers side, regardless of what combination of heater controls. I checked the servo arm in the passenger side, this seems to be working ok, tried synchronising, no difference, can anyone tell me if there are similar servo motors on the drivers side? and is getting to them the same as the passengers?
