Author Topic: running rough and 3.0 cams...  (Read 1087 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« on: 16 December 2008, 20:39:10 »
i was saying about having the omega running to somebody at work.. now i'v heard an omega run rough as crap with the fuel guage on empty and it develope the miss fire of doom :P (so i know what it sounds like)
...i'v got very similar symptoms on my 2.5 with 3.0 cams in... if the timings very almost spot on with cams 1 and 2 with the line on the cams just to the left of the timing guage marking...(it's not even half a tooth out its with the lines touching the guage lines if that makes sense)
my question is:
is it because i need to bleed the air from the fuel rail(as i didnt have time to bleed it and i was in need of somebody to try and start to car to piss fuel and the air out) or is it the timing causing it to run slightly rough or is it just down to fueling so leave it be?
thanks
« Last Edit: 16 December 2008, 20:42:01 by grainqey »
V8!!!!
markey mark
  • SLady bitshorpe north lincs
Re: running rough and 3.0 cams...
« Reply #1 on: 16 December 2008, 20:40:29 »
cam timing needs to be spot on alex ! deffo with 3.0 cams  :o
ngrainqey
  • rotherham
« Reply #2 on: 16 December 2008, 20:42:32 »
hmm... okay markey, i shall get them spot on then this next weekend :P
V8!!!!
markey mark
« Reply #3 on: 16 December 2008, 20:43:16 »
which timing kit you using alex
