Author Topic: clock pixels  (Read 1737 times)
nick v6
  • walsall / west midlands
clock pixels
« on: 16 December 2008, 16:12:11 »
is there any way of repairing the pixels in the clock part of the dash that tells you the time, radio station, mpg, fuel range etc, etc
rickyboy
  • Glasgow
Re: clock pixels
« Reply #1 on: 16 December 2008, 19:53:24 »
There is a way which involves scraping the oxides off the ribbon at the bottom of the unit.  There is a how to on the web somewhere but you would be better just to buy a working second hand unit and have it programmed (if needed).
To repair this is not an easy job and very time consuming with not always great results.  I got mine off ebay but I'm sure there will be a seller on here somewhere.
You have to take the unit out (very easy and how to in the maintenance section) and look at the colour of the plug.  When replacing the unit you must use an identical colour of plug.
Re: clock pixels
« Reply #2 on: 16 December 2008, 19:56:22 »
Is your computer lines above radio line, or below?
If above, they rarely fail, so loads of 2nd hand ones.  If below, they are poor, always fail, and finding a perfect one is rare.
Either way, it needs programming to match the config of your car
markey mark
  • SLady bitshorpe north lincs
Re: clock pixels
« Reply #3 on: 16 December 2008, 20:01:31 »
think his car is a 94 so will be the early black and yellow plug ! like rocking horse poo now !!  :(
Re: clock pixels
« Reply #4 on: 16 December 2008, 20:02:56 »
perfect ones are.  Even many of the supposed 'no missing pixels' have lines on them
DC
  • Switzerland
Re: clock pixels
« Reply #5 on: 16 December 2008, 21:16:13 »
does anyone know the link to the repair procedure? i have a non-working one sitting in a cuboard and would try fixing it to have a spare
Re: clock pixels
« Reply #6 on: 16 December 2008, 22:15:16 »
if its the lcd end on ribbon, no chance. If its pcb end of ribbon, gently peeling back, cleaning contacts, and reattaching.
DC
  • Switzerland
Re: clock pixels
« Reply #7 on: 16 December 2008, 22:35:53 »
lcd end on ribbon :-? pcb end of ribbon :-?
Is that English? Sorry TB but I've got no clue what you are talking about.
BTW, peeled the ribbon back, cleaned contacts, how best to reattach
nick v6
Re: clock pixels
« Reply #8 on: 16 December 2008, 23:03:59 »
mine is a 94 on the m plate
ive not took the clock out
i have to take it out soon to change the bulbs behind the speedo
