Author Topic: tyre sizes  (Read 1939 times)
nick v6
  • walsall / west midlands
tyre sizes
« on: 16 December 2008, 17:05:55 »
im going to replace my tyres after crimbo
whats the best size i should have on my 17 inch wheels
at the moment i have got 245 / 45 r 17 on the front
and 255 / 40 r 17 on the rears
thanks
markey mark
  • SLady bitshorpe north lincs
Re: tyre sizes
« Reply #1 on: 16 December 2008, 19:21:35 »
the proper size for them rims is 235/45r17 matey !!  :y
Albatross
  • Bedford
  • An LSD & an S2000!
Re: tyre sizes
« Reply #2 on: 16 December 2008, 19:21:55 »
The tyres on your car are the wrong size.
This is important because your speedometer is out, as is your odometer.
Standard size is 235x45x17.
By all means change your tyres, but do it properly and keep them within the tolerance on the dynamic rolling radius or get your car reprogrammed to match.
If you're asking for the correct tyre sizes to fit then anything that has a dynamic rolling radius the same as or +/- tolerance of 2.5% of the standard 235x45x17.
I have 235x35x19 on the front and 265x30x19 on the rear.
Check here for comparative details:
http://www.etyres.co.uk/tyre-size-calculator.htm
Check on these two sites if you want to see what they'll look like from the side or above respectively as these are visual comparative sites.
http://www.kouki.co.uk/utilities/visual-tyre-size-calculator
http://www.wheelsmaster.com/rt_specs.jsp
« Last Edit: 16 December 2008, 19:55:25 by Albatross »
nick v6
Re: tyre sizes
« Reply #3 on: 16 December 2008, 19:24:14 »
can i go wider on the rear if so wat size
Albatross
  • Bedford
Re: tyre sizes
« Reply #4 on: 16 December 2008, 19:46:01 »
Look at the links...
I don't know what else you need other than someone else to use that site for you.
« Last Edit: 16 December 2008, 19:56:05 by Albatross »
nick v6
Re: tyre sizes
« Reply #5 on: 17 December 2008, 08:15:13 »
thanks for the help
im gonna see my mate at bmtr aftert crimbo and get the tyres at trade price
