Author Topic: electrical fault  (Read 1300 times)
geoff
  • thornaby,stockton on tees
electrical fault
« on: 18 December 2008, 07:44:09 »
can anybody help,when starting car lights on dash and head lights flicker for about 30 seconds then seems o.k only does if first started or stopped then when you started again,but after that it is o.k,hope some one can help,was told by brother it could be voltage regulater,if so where is it :y :y :y
Re: electrical fault
« Reply #1 on: 18 December 2008, 08:26:18 »
Sort your avatar m8 - its hugh!!
geoff
« Reply #2 on: 18 December 2008, 10:05:31 »
sorry ::) ::)
« Reply #3 on: 18 December 2008, 10:05:31 »
Post unreadable due to avatar size .. 1024 x 819 !!
site limit is 110 x 110 !!
« Last Edit: 18 December 2008, 10:05:54 by entwood »
« Reply #4 on: 18 December 2008, 10:25:49 »
Check battery terminals are tight? Or would the car stall as well?
geoff
« Reply #5 on: 18 December 2008, 15:15:59 »
battery terminals are tight and no it does not stall runs o.k :y :y :ysorry about the hugh pic will try to sort it
« Last Edit: 18 December 2008, 15:17:24 by geoff »
