Author Topic: Radiator flush  (Read 1507 times)
ians
  • Reading
Radiator flush
« on: 18 December 2008, 13:05:53 »
What is the most thorough means to flush the rad?
I have flushed with water with the rad in situ - ie drain through red tap, top up expansion tank, run a bit and repeat.   The water runs clear - no crap whatsoever.
Is it worth removing the rad when I do my cambelt/waterpump and are there any potions worth using?
Richie London
  • heathrow
Re: Radiator flush
« Reply #1 on: 18 December 2008, 13:23:41 »
i undid the drainage plug and just run water through for a while
Abiton
Re: Radiator flush
« Reply #2 on: 18 December 2008, 13:29:22 »
Surely top and bottom hose off, then lots of water hosepiped through, one way then the other.  Kitchen tap on full bore through the hose.  That's what I'd do, if I wanted to be thorough.
Like the heater matrix (see http://www.omegaowners.com/forum/YaBB.pl?num=1228657190/0#0), I suspect the main radiator is lots of small pipes in parallel, so just running a small flow through has no chance of clearing any of these that are blocked, 'cos it'll just flow through the others that aren't.
« Last Edit: 18 December 2008, 13:31:11 by Abiton »
Re: Radiator flush
« Reply #3 on: 18 December 2008, 15:08:45 »
I removed a radiator which had suffered from the oil cooler letting go and left it overnight with Fernox central heating household stuff in it and that did a good job, just keep it away from the grass ::)
ians
  • Reading
Re: Radiator flush
« Reply #4 on: 18 December 2008, 22:22:27 »
Something like this I assume Pete?
http://www.screwfix.com/prods/51463/Plumbing/Central-Heating-Treatment/Fernox-Heavy-Duty-Central-Heating-Cleaner-500ml#
or would it be better putting this in to the coolant system and driving the car around for a bit?
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_274607_langId_-1_categoryId_165750#dtab
Presumably not a clever idea to use the Fernox in the system, just with the rad removed and then flushed thoroughly..
