Author Topic: Funny wereing noise.  (Read 1363 times)
marlcdx
  • Stoke on Trent
« on: 18 December 2008, 20:59:17 »
I have just changed the two front disks and replaced all of the disk pads (front and back) plus had two new tryes fitted at the front P6000's.
Now when I am driving i can hear a funny wereing noise cominng from the front, checked everything is OK, but I am not sure what else to check for.........any ideas
Re: Funny wereing noise.
« Reply #1 on: 18 December 2008, 21:01:25 »
Wheel bearing?
vauxfan2k
  • Western Isles
« Reply #2 on: 18 December 2008, 21:02:30 »
check that the back plates for the discs arent rubbing on the discs,quite common for them to ge a little out of shape with age and rub on the back of the discs.
jack up one wheel at a time and rotate it a few turns, you should hear the culprit.
neimsn
  • Southampton
  • Boy Racer at Heart.
« Reply #3 on: 19 December 2008, 10:19:42 »
Hi Matey,
I have just experienced the same problem when changing to a new tyre, spoke to the tyre centre that fitted it and they reckon its the rubber compound of the tyre causing the noise, I too thought it was a wheel bearing at first.
MORTY
  • suffolk
« Reply #4 on: 19 December 2008, 16:06:14 »
Have just fitted a new set of tyres to mine, and it making the same noise. hopefully it will settle down it time. ::)
