Author Topic: CCR 2006  (Read 1500 times)
alpha31
  • scotland
CCR 2006
« on: 19 December 2008, 16:38:53 »
Turned on the head unit this afternoon to find I cant get any sound at all from the unit, reset the security code and not even the usual beep from that!
Everything works as it should CD/Radio/Tape and the controls from the steering are working.
Does any one know if there is a output mute function.
Cheers Mark
Danny
  • Wigan, Greater Manchester
Re: CCR 2006
« Reply #1 on: 19 December 2008, 19:46:57 »
although without sound, does it show the usual visuals on display?
try removing the whole headunit and replacing, incase its a loose connection
my ncdc2013 gave up one day in my elite, display went off and everything, after a stroke of bad luck turned-good, the car battery went flat and when i recharged it, the unit "re-found" its connection and worked fine ever since
alpha31
  • scotland
Re: CCR 2006
« Reply #2 on: 19 December 2008, 22:10:38 »
Thanks for reply Danny, the display is as normal.
I had to replace the battery 6 weeks ago, usual set up of resetting code and unit worked fine.
Will try disconnecting the battery.
Cheers
Re: CCR 2006
« Reply #3 on: 19 December 2008, 22:12:31 »
Is there a phone kit fitted?
alpha31
  • scotland
Re: CCR 2006
« Reply #4 on: 19 December 2008, 22:13:35 »
No phone kit fitted, its as standard as the day it came out of the box.
    • 530D M Sport, 330i Coupe
Re: CCR 2006
« Reply #5 on: 19 December 2008, 22:56:38 »
Or a Trafficmaster fitted?
fife_omega_v6
Re: CCR 2006
« Reply #6 on: 19 December 2008, 23:00:43 »
Cheers
Had same problem had to fiddle with multi function on the steering wheel and started working
« Last Edit: 19 December 2008, 23:01:15 by fife_omegav6 »
[img name=signat_img_resize]http://i404.photobucket.com/albums/pp123/fife_omega_v6/IMAGE_00054-1.jpg[/IMG][img name=signat_img_resize]http://i404.photobucket.com/albums/pp123/fife_omega_v6/IMAGE_00059-1.jpg[/IMG]
alpha31
  • scotland
Re: CCR 2006
« Reply #7 on: 20 December 2008, 14:48:01 »
Had Trafficmaster fitted as part of Norwich Union "Pay As You Drive" Insurance but it has its own seperate speaker.
Tried disconnecting the power supply to the unit and re entering the code all to no avail! Still no sound!
 :-X
fife_omega_v6
Re: CCR 2006
« Reply #8 on: 20 December 2008, 20:55:05 »
theres a mute buttin on the satelite stub mounted on same side as wipers control, the buttons on the underside ,that was problem with mine after i had battery out it wouldnt give any sound..
Cheers
