Author Topic: Lack of grunt...  (Read 2680 times)
damon80
  • Wigan
Lack of grunt...
« on: 21 December 2008, 00:42:57 »
Hi again folks...
Not sure if this is related if my other posts, but...
My Miggy seems quite a bit down on grunt.
As I've said before - the 2nd from the left outlet on the breather box has broke off, but am going to fit a new un tomorrow.
Is this likely to fix things?  :-? Or is it going to be a multi-ram problem?
I can "tickle" the accellerator, and she picks up ok, but if I plant it - well, there is nowhere near as much grunt as there was from my last 3.2 Manual Miggy  :(
Anyone any suggestions?  :-?
Cheers  :y
markey mark
  • SLady bitshorpe north lincs
Re: Lack of grunt...
« Reply #1 on: 21 December 2008, 00:46:32 »
could be both mate ! fix whats broken and see how it is then check vac pipes and multirams !  :y
damon80
  • Wigan
« Reply #2 on: 21 December 2008, 00:55:02 »
How do I check multi-rams??  :-?
markey mark
« Reply #3 on: 21 December 2008, 01:00:43 »
get your breather fixed then rev hard and you can see them moveing !  :y
damon80
  • Wigan
« Reply #4 on: 21 December 2008, 01:09:03 »
Sorry bud - where should I be looking??  :-?
markey mark
« Reply #5 on: 21 December 2008, 01:24:35 »
one of rear of plenum other at front on alloy part in front of engine !
damon80
  • Wigan
« Reply #6 on: 21 December 2008, 01:31:01 »
Yep, but how do I check um??  :-[
markey mark
« Reply #7 on: 21 December 2008, 01:34:28 »
when you go to andy b he will show you ! you check them by reving the engine hard and someone will have to watch under bonnet !  :y
damon80
  • Wigan
« Reply #8 on: 21 December 2008, 01:38:14 »
Cheers bud - no doubt Andy B will show me the way - if he don't mind...
It really is wierd - on half-throttle, can feel the torque of the motor.  But on full throttle - well, there's sweet f.a. difference...  :-[
markey mark
« Reply #9 on: 21 December 2008, 01:41:52 »
strange that at 4500ishrpm it should take off  :-?
« Reply #10 on: 21 December 2008, 01:42:07 »
PM sent. It'll be a suck it & see (ooer) as I've never really had any need to play withtye vacuum & dual ram on my car ..... but I'm sure we could could sort it.  :y
« Last Edit: 21 December 2008, 01:42:25 by Andy_B »
markey mark
« Reply #11 on: 21 December 2008, 01:44:48 »
not too bad andy just follow the guide for vac pipes in maint sec  :y
« Reply #12 on: 21 December 2008, 01:48:19 »
 :y  :y  :y
Pete Elite
  • Uxbridge, Middlesex
« Reply #13 on: 21 December 2008, 15:12:17 »
Hi again folks...
Cheers  :y
               Put a[size=14][size=16] Piggy [/size][/size]in your [size=14][size=16]Miggy[/size][/size] ;D ;D ;D.
markey mark
« Reply #14 on: 21 December 2008, 15:14:47 »
Hi again folks...
Cheers  :y
weres your coat bud !!  ::) ::)
« Last Edit: 21 December 2008, 15:15:04 by markey_mark »
