Author Topic: Auto box problem  (Read 1150 times)
Richard A
  • Aldridge, West Midlands
Auto box problem
« on: 23 December 2008, 18:10:44 »
While driving around town, ie stop/start, the auto goes from 1st up the gears no problem but if I have to then slow down again say when in 2nd I can hear/feel a mild 'thud' from the box as I decelerate, does not sound good. Changed ATF & filters at 134k (now152k) checked level at 148k. Works very well except for this. Advise please.
regards
richard a
richard a
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: Auto box problem
« Reply #1 on: 23 December 2008, 22:47:50 »
n idea of your problem but can supply a good ar25 if thats what you'll need for 40 pounds ;)
*edit:
it's only done 95k btw
« Last Edit: 23 December 2008, 22:48:14 by grainqey »
V8!!!!
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #2 on: 24 December 2008, 10:52:49 »
The thudding noise could be symptomatic of thrust washer failure. Do a search on "dreaded thrust washer". Mine had similar noises/feel always at the same point on a familiar journey. My gearbox had done about 130k miles.
If it has developed some miles after your last gearbox oil change, if you drop the sumps off the pieces of the broken plastic thrust washer will be in the sump.
El Varche
Richard A
« Reply #3 on: 24 December 2008, 12:17:33 »
Thanks for the replies, as a P.S. it only seems to happen when the engine is hot ie 96 degrees/as the the first fan cuts in.
Could it be the make of ATF which is less effective when hot ?
regards
richard a
richard a
