Author Topic: windscreen wash  (Read 1573 times)
Richie London
  • heathrow
windscreen wash
« on: 24 December 2008, 13:33:28 »
holes are not blocked but im still not getting any water out, where do i need to start to finding the fault in it. no fuses are blown could the tube have come off somehwere along the line, is ok on the bonnet.
cheers
hoj
  • BURY
Re: windscreen wash
« Reply #1 on: 24 December 2008, 13:41:26 »
This happened to me once and it was just a case of checking all the line and connections, it ended up being the pipe connected to the motor that must have been pulled of and put back that many times it was loose and just started to pop off when the washers were turned on
3.2 Elite in Oyster
Richie London
  • heathrow
Re: windscreen wash
« Reply #2 on: 24 December 2008, 13:44:03 »
whereabouts is the motor, and how do i get to it
Welung666
Re: windscreen wash
« Reply #3 on: 24 December 2008, 13:45:52 »
The pump is in the washer bottle behind the front bumper. You should be able to reach to check if you pop the grill off :y
markey mark
  • SLady bitshorpe north lincs
Re: windscreen wash
« Reply #4 on: 24 December 2008, 13:47:11 »
on the bottom of motor is a little filter bud ! take grill off and you can see pump pull it out and filter is like a rubber grommet in tank take that out clean and refit !  :y
Richie London
  • heathrow
Re: windscreen wash
« Reply #5 on: 24 December 2008, 13:54:03 »
brilliant, im so frigging bored ive now got something i can go and do,  ;D ;D
hoj
  • BURY
Re: windscreen wash
« Reply #6 on: 24 December 2008, 14:04:22 »
Think of me rich i havn't worked for 3 weeks (building trade) i have even resorted to checking oil, water, brake fluid, also washing and waxing the car
Beats stuffing the turkey tho
3.2 Elite in Oyster
Richie London
  • heathrow
Re: windscreen wash
« Reply #7 on: 24 December 2008, 14:30:12 »
same here. im a shopfitter, had plenty of work just too ill.
took grill off, motor doesnt seem to be working at all, not a sound when i do the wiper arm. ???
