Author Topic: 2.5 V6 Ever had this problem? Missfire  (Read 1412 times)
hoj
  • BURY
« on: 23 December 2008, 16:35:14 »
My 2.5 V6 runs spot on normally (fast and reliable)
However all of a sudden after heavy rain it either has trouble starting or starts but then missfires when warm, like as though its only running on 5 cylinders.
So you start to think is it the plugs? Is it the fuel filter? Is it the plug leads or is it something worse. Is it electrical or fuel related
Have the plugs been changed recently? Have i got dirt in the fuel tank and where did i fill up last.
I will give a big xmas kiss to anyone who can guess what the problem was - go on you know you want to play along it is xmas after all.
3.2 Elite in Oyster
jonathanh
  • coventry
Re: 2.5 V6 Ever had this problem? Missfire
« Reply #1 on: 23 December 2008, 16:39:48 »
likely to be water on the cables or dis pack.  do your best to dry it out and then see if you have a problem.  Likely to be related to heay rain.
ians
  • Reading
« Reply #2 on: 23 December 2008, 16:56:54 »
Is this a game or a real problem?
Is rain is leaking through the wiper spindle hole in the scuttle and down onto the drivers side camcover/no. 5 plug lead area?
Richard A
  • Aldridge, West Midlands
« Reply #3 on: 23 December 2008, 18:21:55 »
Check the 'joint' between the two parts of the 'plastic scuttle', in heavy rain water leaks onto No6 plug and the 'dispack', try a big can of WD4? to see if it makes a difference.
regards
richard a
richard a
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #4 on: 23 December 2008, 18:33:43 »
regards
richard a
I was going to say the same... HBV ain't leaking is it?
hoj
  • BURY
« Reply #5 on: 23 December 2008, 21:24:47 »
XXX    ians won the game
seriously tho didnt know this was a known fault water getting thru the wiper arm spindle
£138 to fit plugs, fuel filter and air filter and just before xmas.
All OK now sealed the spindle too best i can
3.2 Elite in Oyster
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #6 on: 25 December 2008, 12:07:44 »
my dad had a camaro which used to dump water onto the dispack lol!
wasnt a very good idea... also the bootlid used to throw water in the boot depending if you parked it forwards down a hill or uphill!
V8!!!!
bigdods
  • Brackley
« Reply #7 on: 25 December 2008, 21:36:29 »
My 2.5 did exactly that. One day heavy rain and down to 5 cylinders. DIS pack was FUBAR'd , turns out water had been leaking onto it for quite a while and it was badly corroded. The heavy downpour finished it off. 2 sockets were corroded and the leads knackered as well so ended up with new DIS pack and a full set of leads. And new plugs as I'd had to drive it quite a distance missing on 1 or 2 cylinders all the way.
