Author Topic: Changing manual gearbox oil  (Read 1148 times)
Arrolman
  • Renfrew,Scotland
« on: 26 December 2008, 19:11:40 »
Hi,
Hope everyne had a good christmas! Im going to change the oil in my gearbox, feel its getting a bit notchy in 1st/2nd and the cars pushing 80,00 so think its due. Is this an easy job or do I need to drop the sump? Recommended oil? Any filters?
Cheers,
Iain
Looking to win the lottery..........
Re: Changing manual gearbox oil
« Reply #1 on: 26 December 2008, 19:13:42 »
Easy on a manual......remove the drain plug to empty and re-fill via the level bung to 8mm below the level plugs edge.....takes about 1.2 litres of fluid
Omegatoy
  • UK
« Reply #2 on: 26 December 2008, 20:06:20 »
before you undo the drain plug make sure the filler plug comes undone easily!!! have known 2 or 3 people drain them than not be able to get the filler undone as it chews up and then  you cant drive the car!!!! :y
Arrolman
  • Renfrew,Scotland
« Reply #3 on: 26 December 2008, 21:47:03 »
Hi,
Thanks for that, good point Omegatoy :y
Cheers,
Iain
