Author Topic: Front Seat Release Bar  (Read 1303 times)
gwa
  • Peterborough
  • Ginger With Attitude
« on: 25 December 2008, 13:17:50 »
Went to the Hand Car Wash yesterday and had a inside and out done... Looks good :y
I noticed the front passenger seat was closer to the dash than it should be, so I grabbed the bar and guess what, yep one end is flapping in the breeze.
How does the bar fit to whatever under the seat? and is it easy before I bust a knuckle or something...
Thanks in advance
Merry Christmas  :) :-* :)
If it ain't fun, it ain't worth doin
Re: Front Seat Release Bar
« Reply #1 on: 26 December 2008, 20:07:52 »
Never seen that before.......new seat base job for that!
gwa
  • Peterborough
« Reply #2 on: 27 December 2008, 11:38:02 »
Thanks Mark, can you explain a bit more please.  :y
« Reply #3 on: 27 December 2008, 11:50:19 »
You seat base is fubar'd and you need another/new-to-you as a replacement! ;D  ;D
The seat fastens to a frame/base that is then bolted to the car floor.
gwa
  • Peterborough
« Reply #4 on: 27 December 2008, 12:13:59 »
Thanks Andy. Do I get/trust one from a scrappy?
« Reply #5 on: 27 December 2008, 13:38:07 »
I would. As Mark suggests, you've been very unlucky for your seat base to have broken, it's not a common failure.  :y
Just be aware of airbags & seat belt pretensioners when you remove your seat. It's best to disconnect you battery before you do the job, as a very minimum don't turn the ignition on with the seat removed (electrically) or you'll trigger the air bag warning light which will need a 'Cheapo' or real Tech II to reset it.
« Last Edit: 27 December 2008, 13:40:38 by Andy_B »
