Author Topic: Odometer not working  (Read 1393 times)
Alldi
  • Hampshire
« on: 22 December 2008, 12:51:27 »
The odometer and trip meter has stopped working on my 99 Elite 3.0. All the other instrument functions work fine.
I recently had the oil level sensor replaced, so I'm wondering if they've done something that could cause these symptoms.
If not where should I start investigating?
Many thanks for any help :)
Re: Odometer not working
« Reply #1 on: 22 December 2008, 18:46:31 »
If the speedo still works, I would look towards instrument failure....
« Reply #2 on: 22 December 2008, 19:47:25 »
....... and if the speedo does not work, then it suggests ABS ECU
pigtown
  • swindon
« Reply #3 on: 29 December 2008, 16:24:04 »
Got the same problem with my 2.2 petrol.
The speedo works fine but no miles clocking up.
The computer trip reading works fine so it is getting a signal from somewhere!
Is there a cable for the odometer drive?
Cheers & happy new year!
« Reply #4 on: 29 December 2008, 16:26:14 »
Is there a cable for the odometer drive? .....
Nope! :( Sounds like you need a 'new' speedo/dash!  :(  :y  :y
« Reply #5 on: 29 December 2008, 21:43:23 »
No cables on the 2.2, it would get the reading from the engine ECU or such like, try swapping out the dash
« Reply #6 on: 29 December 2008, 23:18:37 »
Or any of them. The last Vauxhall that I had with a cable driven speedo was my 2.2 CIH Carlton.  :y
They're driven via the ABS.
« Last Edit: 29 December 2008, 23:20:12 by Andy_B »
