Author Topic: GM4L60E...  (Read 4415 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
GM4L60E...
« on: 28 December 2008, 22:29:11 »
does anybody know anything about these, might beable to get one thats all...
are they a straight bolt onto the omega or do they have a seperate bellhousing that bolts on so would have to swap it for the omegas?
thanks
V8!!!!
Re: GM4L60E...
« Reply #1 on: 29 December 2008, 10:06:40 »
Seperate bellhousing....how the hell are you going to get the electrics to work on it!
It is only a 4 speed unit by the way.
http://www.novak-adapt.com/knowledge/4l60e.htm
ngrainqey
  • rotherham
Re: GM4L60E...
« Reply #2 on: 29 December 2008, 13:17:56 »
lol i know it's 4 speed "GM4L60E"
it should be the same electrics except maybe the shape of the plugs shouldnt it?
thanks
V8!!!!
Re: GM4L60E...
« Reply #3 on: 29 December 2008, 13:39:45 »
thanks
I doubt its anything like the same.....
ngrainqey
  • rotherham
Re: GM4L60E...
« Reply #4 on: 29 December 2008, 14:55:01 »
lol i'll just have to try and "trick" the ecu :P
but might result in a bad changing, engine light gearbox lol
you really think the wiring will be different mark?
thought it might just be for example different shaped connecters
thanks
V8!!!!
    • 530D M Sport, 330i Coupe
Re: GM4L60E...
« Reply #5 on: 29 December 2008, 15:03:22 »
Use the 5L40 instead!
ngrainqey
  • rotherham
Re: GM4L60E...
« Reply #6 on: 29 December 2008, 15:07:33 »
but they're harder to get and more expensive?
V8!!!!
Re: GM4L60E...
« Reply #7 on: 29 December 2008, 15:14:18 »
If this is for your turbo conversion I reckon a Manual box would be a better bet.
Sassanach modified a few AR35's (4L30) to make them more 'towing friendly'. Not exactly sure what he did but may be worth PM'ing him.
ngrainqey
  • rotherham
Re: GM4L60E...
« Reply #8 on: 29 December 2008, 17:11:03 »
i quite fancy having the potential torque ability really then it doesnt matter how far i go really... maybe an auto v8 project but i'd rather get something i can bolt straight onto the omega engine and im not bothered wether its 4 or 5 speed (they did 4 and 5 speed gm boxes on the camaros)
V8!!!!
Re: GM4L60E...
« Reply #9 on: 29 December 2008, 18:19:54 »
Well, here's what I'd do:
Given that you've got a seriously modified engine in mind anyway I would ditch the OEM Engine ECU and use something mappable. That makes using the OEM auto gearbox ecu hard anyway, since it will lose its' communication with the engine, and, as said, adapting it to the 4l60 is not going to be trivial.
There are some guys here experimenting with a home made controller for the 4l60 that will talk to a Megasquirt. http://www.msgpio.com/forums/viewforum.php?f=4&sid=893c696023627ab08ade6f4d4d412dc7
It won't be straightforward but will allow you to tune and tweak it around your tuned engine and set it up exactly how you want. You will need to get your hands dirty, though. Very dirty.
Actually, I lied. What I'd do is to use a manual gearbox. ;)
ngrainqey
  • rotherham
Re: GM4L60E...
« Reply #10 on: 29 December 2008, 18:33:02 »
haha! kevin, i'd like to go manual but then it involves clutches.. the clutch pedal which i dont have in any of mine and then it requires a good solid gearbox.
i thought of the gm4L60E because i thought it might be easier to get to work (being gm and only really being quite alot higher torque rating)
didnt they use the 5L40E on the last 3.2's?
V8!!!!
Re: GM4L60E...
« Reply #11 on: 29 December 2008, 18:42:03 »
I personally think the manual route would be much less work, granted that you'd need to swap the pedals with a manual car and add a clutch master cylinder, change the prop, flywheel, etc.
The problem with using a different auto gearbox is that the way the ECU drives the actuators is tuned to the hydraulic system of the gearbox and the ratios it uses. Assuming that all the sensors and solenoids are broadly compatible you could end up, for example, with an ECU that doesn't shift "hard" enough for the gearbox, meaning it'll wear rapidly.
Of course the ECU might just decide it doesn't like the ratios in the new gearbox and go into limp home.
I think a gearbox controller that you can tune or an uprated autobox that's not electrically controlled (or just has crude lockup and overdrive solenoids to worry about) are the only feasible automatic options.
I believe there were Omegas with the 5L40E but not in this country, sadly. :(
philhoward
  • Staffs
  • Love the engines, so put one in something else..
Re: GM4L60E...
« Reply #12 on: 29 December 2008, 19:14:24 »
Just go for the latest non-electronic gearbox you can find...
ZF 4HP22?  It did fine on the Wife's XJS... lovely box!
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
ngrainqey
  • rotherham
Re: GM4L60E...
« Reply #13 on: 29 December 2008, 19:22:07 »
you know when you tune the omega for example with the ar25 gearbox, what actually happens when you use too much power through it?
just cooks the oil or what?
V8!!!!
ngrainqey
  • rotherham
Re: GM4L60E...
« Reply #14 on: 29 December 2008, 19:32:26 »
oh yeah, if your saying about using a none electronic autobox then what about the tremec gearboxes off the camaros and stuff?
V8!!!!
