Author Topic: MV6 Gearbox Concerns...  (Read 1510 times)
BettyBlu
« on: 30 December 2008, 02:00:39 »
I'm just wondering if the following are signs that now is the time to have a gearbox strip down?
When cold 1st very notchy but engages ok, but requires more force and guidance than when warm.
When cold, reverse is almost impossible to engage unless I double declutch, select 3rd then 4th. It then slots in nice and smooth, no problem at all.
Car is genuine 86000 miles with FSH.
Any info much appreciated, thanks.
signature pic deleted as it exceeds forum guide size....
Re: MV6 Gearbox Concerns...
« Reply #1 on: 30 December 2008, 03:18:11 »
have seen talk of changeing the manual gear box oil on here, never done it myself so cant advise. I suppose should ask if the clutch is disengaging fully?
« Reply #2 on: 30 December 2008, 13:52:14 »
I would bleed the clutch and change the gearbox oil before paying for a strip down. The manual gearboxes are very strong and 86000 miles is nothing ;)
BettyBlu
« Reply #3 on: 30 December 2008, 17:06:28 »
Thanks, yes clutch is disengaging fully. When all is warm the gearbox is fine across the whole gate although it does not like to be rushed changing up or down. But I hear this is a characteristic of the 'box anyway.
So the VX claims of 'lifetime' oil in the gearbox are stretching it a bit then?
It's been years since I've done a gearbox oil change. Think that was on some FWD Renault and was one of the trickiest jobs I've ever had to do. But that's Renault's for you...
« Reply #4 on: 30 December 2008, 17:12:13 »
Its very easy on a manual, the only thing I would say is make sure the filler plug can be undone before undoing the drain plug ;)
BettyBlu
« Reply #5 on: 30 December 2008, 17:17:52 »
Ah, a drain plug - that does sound promising ;) The Renault I refer to above didn't have one and you had to insert a pipe through the filler and extract the old oil.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #6 on: 30 December 2008, 21:20:32 »
MV6's Box is very strong takes loadsa stick!
they are strange beasts and the gear change takes alot of getting used to
Page created in 0.034 seconds with 16 queries.
