Author Topic: Help me choose some tools!  (Read 3458 times)
« on: 09 November 2007, 22:52:40 »
Hi Guys. Please help me improve my toolkit, with suggestions on what I could get.
I have:
Halfords Pro 150pc socket set, Inc ratchet spanners, and male/female Torx required for Omega
Alan keys, all sizes needed.
Halfords Pro low range torque wrench, 8-60nm
Clarke Pro higher range torque wrench, 27-280nm (no longer trust it, will soon be replaced)
Assorted metric sockets on rails, from 6mm to 30mm, both 3/8 and ½
Loads of assorted ratchets, additional to the socket set
1/2 drive tommy bar
Large collection of various random imperial sockets
½ inch drive E20 for turning crankshaft
Sykes Pickavant Cam locking / setting tools, and 30mm spanner
Clarke Pro 3 tonne hydraulic trolley jack (great bit of kit)
3 tonne axle stands
Loads of assorted pairs of mole grips, pliers, more ratchet spanners, Wire cutters, Hacksaw, hammer and mallet.
Assorted spanners, from 6mm through to 22mm
Decent valve spring compressor and grinding stick/paste
Rail of Crowfeet spanners up to 22mm (for oil coolers)
Hand made tool for locking crank to remove toothed pulley (Cheers Sassanach!)
Small LED torch and maglite
Various screwdrivers + sturdy pry bar
Fork type balljoint splitter
Screw type balljoint splitter
Clutch alignment tools
Fluid pumping tool (gearbox filling)
Oil draner and funnel
"Magic" sockets, for removing rounded bolts
Wish list:
24mm open end spanner (for EGR)
Tap and Die + Helicoil kit
Decent breaker bars, all sizes
Torx spanners
Better torque wrench
Proper clutch/brake bleeding device (air driven)
Second jack (for fitting gearboxes) – ideally a tranny jack!
Cheapo Tech2
Angle measurer
Compression tester (I stood on mine :( )
Creeper
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
Re: Help me choose some tools!
« Reply #1 on: 09 November 2007, 22:59:05 »
As far as I can see you have most things covered.
The only obvious ommissions are a jumbo pack of dilithium crystals and a sonic screwdriver, then your set.
[size=24]        [/size][/b]
« Reply #2 on: 09 November 2007, 23:02:37 »
You are definitly missing a thingamyjig for undoing whatchamacallits ... :(
« Reply #3 on: 09 November 2007, 23:04:21 »
Tap and Die
I've got a couple of cheapie sets of these. They do the job. Depends how hard the material is and whether you're going to use it every day or just occasionally.
I find the Halfords Professional ones to be good.
I had an ezebleed but it fell to bits and it's a PITA to have to use a tyre as the air source. I've now bought myself a small garder sprayer (killaspray type thing but very cheap from ALDI. Even has a pressure gauge!). My plan is to get a couple of old brake fluid reservoir caps and fit the pipe into the top. Chuck a little brake fluid in, pump it up and go round each bleed nipple.  :y I'll let you know if it works or if I get doused in brake fluid. IME the suction ones are pants. as are the "one man" kits with a one way valve in the tube. Air gets sucked in around the bleed nipple threads.
Cheapo Tech2
Hungarian one does the job for me with suitable lap top.
Angle measurer
Compression tester (I stood on mine Sad )
I've got the gunson one. Get a deep reach adaptor too as it's too short for most twin cam heads. Don't get one with a press on rubber seal because it's a 2 man operation - if it works!
Creeper
Got a Halfords one for Christmas last year. Once I got bored of using it as a luge it was great for getting under cars :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #4 on: 09 November 2007, 23:05:04 »
I usually find an enthusiastic young boy who can be bribed/bullied into doing the uncomfortable bits is indispensable.
TuBy's new whipping boy.
« Reply #5 on: 09 November 2007, 23:06:55 »
Kev - angle measurer - for measuing angles when tightening bolts. Eg, head bolts through 90 deg :y
« Reply #6 on: 09 November 2007, 23:10:27 »
Ah, with you :y
I've got one of those. You're not going to like this.  ::)
I think it's a Laser one :-X
Golfbuddy
  • Cornwall
« Reply #7 on: 09 November 2007, 23:11:31 »
Can you get those at Halfords?
« Reply #8 on: 09 November 2007, 23:12:36 »
Ah, with you :y
A bit like your cheap nasty timing kit? ;)
(Sorry, I couldn't help myself).
I'd love to check an engine timed up with that, using my SP kit. May be interesting test to do.
Not all laser stuff is bad mind. My valve spring compressor is Ace, and that's a laser tool!
« Last Edit: 09 November 2007, 23:13:17 by JamesV6CDX »
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #9 on: 09 November 2007, 23:13:47 »
Dunno but they can eat loads of curry then fall asleep in the chair when they get home from the curry house.
« Reply #10 on: 09 November 2007, 23:42:30 »
You still got mine?
IrmscherKris
  • Manchester
  • banned due to bad trader references
« Reply #11 on: 09 November 2007, 23:42:46 »
Go to Halfrauds... get a T/C and rinse they're tools.
Lifetime warranty ya know  :P
« Reply #12 on: 09 November 2007, 23:43:05 »
And the torx sockets :p
IrmscherKris
  • Manchester
« Reply #13 on: 09 November 2007, 23:50:15 »
Actually TBH, just buy what you need - when you need.
Thats what I did, works out cheaper too...
« Reply #14 on: 09 November 2007, 23:53:09 »
You still got mine?
No, for the 100th' time, it's in Tunnie's garage, from his Dad's 2.2 work  :P  ;D
Torx sockets - I have your small halfrauds rail. Sat in my toolbox doing nothing. I'll drop them over next time I come, if you don't need them urgently.
