Author Topic: HEATING NOT WORKING  (Read 5330 times)
ZEE
HEATING NOT WORKING
« on: 22 December 2008, 01:35:44 »
HI
WELL I HAVWE BOUGHT THIS OMEGA W REG 2.5 AND V6 ENGINE CAR IS EXCELLENT BUT THE PROBLEM I HAVE HEATING IS NOT WORKING AND IS BLOWING COLD AIR ON HI TEMP TOO.HAVE GOT THE THERMOE STAT CHANGE AND SOME SWITCH AND VALVE ALONG WITH IT TOO.BEEN TO 2 GUY ONE HAS FLSUHED THE SYSTEM STILL NO DIFFERENCE AND ONE HAS TOLD ME HE RECKONS THE GASKET IS GONE HENCE IT IS NOT BLOWING HOT AIR.BUT CANT SEE THE OIL MIXED WITH WATER NOR THE CAR IS LOSING WATER NOR THERE IS OVERHEATING PROBLEM TOO.SO CAN YOU SUGGEST ME WHAT IT COULD BE.ALSO THE CENTAL LOCKING IS NOT WORKING ON THE REMOTE AND I HAVE OPENED THE KEY FORBE BUT THERE IS NO BATTERY WHICH I CAN REPLACE ANY SUGGESTIONS ON THAT.AND ONE MORE THING I GOT HEATED ELECTRIC SEATS APPARENTLY AND PASSENGER ONE HEATS UP FINE BUT THE DRIVER SIDE NOT HEATING UP WHAT COULD THAT BE?THANX HELP WILL BE MUCH APPRECIATED CAUSE NO ONE IS SURE AND IF I GET THE GASKET DONE UNNECESSARILY THEN ITS GOING TO COST ME A FORTUNE.
markey mark
  • SLady bitshorpe north lincs
Re: HEATING NOT WORKING
« Reply #1 on: 22 December 2008, 02:42:05 »
try flushing the heater matrix first then chaeck all vac pipes ! wont be head gasket very rare on v6s ! battery in keyfob is a cr2032 iirc get one and switch ign on then press buttons on fob to resync ! seat heater is common fault bud  not easy to fix  :(
Welung666
« Reply #2 on: 22 December 2008, 06:56:55 »
Hi Zee, firstly please stop shouting! It's to early in the morning for all that, ta :y
Very unlikely to be the head gasket as they rearely go unless driven for a while while over heating. More likely to be your HBV or a vacuum fault. If your guy has changed them then a few reverse flushes, both ways through the matrix would help. Easily done from the engine bay with a hose, no need to remove much. Your key does have a battery in it for the RCL, not sure how to change them though as mine is the earlier seperate fob. Heated seat failure is normally the element in the seat itself. If cloth seats you can get replacements but leather seats have them stitched to the leather, although it is possible to fit the cloth seat type underneath the broken on in your leather seat. HTH :y
nick v6
  • walsall / west midlands
« Reply #3 on: 22 December 2008, 06:57:58 »
check vac pipes
ive sorted mine by putting the vac pipes the right way round
its a bit of a pain but pretty straight forward once you get your hands dirty
jonathanh
  • coventry
« Reply #4 on: 22 December 2008, 08:12:39 »
Right - first test: run the car up to hot temp, turn the heating on.  then remove the trim above the pedals and locate the alu heater matrix pipes coming through the bulkhead to the left of the pedal area.  If they are both too hot to handle then you are hetting heat to the matrix.  This means your problems lie in the air dist unit.  If you are not getting heat to the matrix then disconnect the vac to the HBV.  If you are still not getting heat to the matrix then chances are the HBV is fitted wrongly.
ZEE
« Reply #5 on: 22 December 2008, 14:19:36 »
hi
thanx guys for your responses!!!! i did manage to find a battery in the other key forbe but the battery holder is indepenedant means it is not actually holding on to nething.and what is HBV i am not  atechnical man so please bare wiht me.how do i flush the system?well the guy said he done some fluid test and it is showing that the water is changing color hence the gasket is gone.so suggest me how i can confirm this please.and my car is automatic if that helps to determine nething.
jonathanh
  • coventry
« Reply #6 on: 22 December 2008, 15:00:32 »
update your profile so we can see where you are.  maybe someone close by can take a look.  I doubt it is the HG.  Typical of a garage to suggest the most expensive thing if thay cannot find the problem.
flevoman
  • Almere  Holland
« Reply #7 on: 22 December 2008, 15:23:28 »
Last week my car's heating  did not work either
Only the first two minutes, after that cold air, bbrr, even with the settings on 28 degrees centigrade.
It was the outside temperature sensor, just 15 euri.
« Last Edit: 22 December 2008, 15:36:15 by flevoman »
ZEE
« Reply #8 on: 22 December 2008, 15:35:09 »
hi #
i am in east london ilford. well i m sure the guy who had a look not specialises on vauxhall there more gemran car specialists.so suggest what i shud do?but cn u actually have problems with heating becuase of headgasket too?everything seems to work fine just that its blowing cold air at hi temp.help me its making me crazy lol and headgasket just doens not seem the problem to me cause car is driving excellent.so ne suggestions or help pls let me know email me (***mobile number deleted***)
« Last Edit: 23 December 2008, 08:46:55 by hotel21 »
jonathanh
  • coventry
« Reply #9 on: 22 December 2008, 17:17:07 »
um - probably best not to post your mobile number.....
have you tried the first check as per my earlier post?  post back what you find and we can help you to the next step
fife_omega_v6
« Reply #10 on: 22 December 2008, 17:17:42 »
hi #
i am in east london ilford. well i m sure the guy who had a look not specialises on vauxhall there more gemran car specialists.so suggest what i shud do?but cn u actually have problems with heating becuase of headgasket too?everything seems to work fine just that its blowing cold air at hi temp.help me its making me crazy lol and headgasket just doens not seem the problem to me cause car is driving excellent.so ne suggestions or help pls let me know email me. (***mobile number deleted***)
Have you checked the heater pipes to the matrix inside the car,positioned to the left above the pedals youll have two alu pipes are they both hot {hardly touch} or warm ..my matrix is blockedat the moment and 1 pipe is blistering hot and the return pipe is warm, and i only getting cold air into the cabin, gona flush matrix tommorow hopefully.....
« Last Edit: 23 December 2008, 08:47:22 by hotel21 »
[img name=signat_img_resize]http://i404.photobucket.com/albums/pp123/fife_omega_v6/IMAGE_00054-1.jpg[/IMG][img name=signat_img_resize]http://i404.photobucket.com/albums/pp123/fife_omega_v6/IMAGE_00059-1.jpg[/IMG]
ZEE
« Reply #11 on: 22 December 2008, 17:27:15 »
how do u flush?is rad flush from halfords works?
fife_omega_v6
« Reply #12 on: 22 December 2008, 18:43:10 »
dont quite know yet the best way im waiting for a answer on this also will let you know tho, its looking like you remove the two hoses going through the bulk head and hose water through each inlet
jonathanh
  • coventry
« Reply #13 on: 22 December 2008, 19:53:57 »
yep - that's basically it.  disconnect the hoses at the bulkhead and get a gaqrden hose onto one.
ZEE- the key to this is to logically identify your problem and then fix it.  It looks like your garage has tried the change this part and see if it works approach, which is much more costly.  Before flushing your heater matrix, determine if it is the problem.  If the matrix is heating up and your problem is the air dist unit, you will waste time/money/effort and get more fed up.
ZEE
« Reply #14 on: 22 December 2008, 20:17:40 »
hi understand wot u mean but the only thing i am concerned is can the headgasket be the cuase of the problem though?cause i been told its the head gasket which is cuasing the problem bouthg the car cheap and then if i have to spend on headgasket then not worht it.the guy i bought it form not responding either.well will look into it and see but the other garage i left it with did actuallyy flush the system though.and is HBV  same as thermostat?
