Author Topic: Front end conversion  (Read 1343 times)
Bumbazor
  • Worksop
« on: 01 January 2009, 13:47:50 »
From pre facelift to faclift.
I think I'm right saying that the bumper is a straight swap, but are the other bits ok or will they need changing too so it fits nicely? For example, bonnet which includes the grill where pre doesn't, headlight bits, etc.
Thanks
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: Front end conversion
« Reply #1 on: 01 January 2009, 13:55:30 »
think its just the bonnet bumper, grill, headlights and underlight trim!
oh and on the facelift you dont both with the windscreen washer tube to the top
V8!!!!
markey mark
  • SLady bitshorpe north lincs
« Reply #2 on: 01 January 2009, 13:55:31 »
headlights and bonnet front bumper is all you need oh and trims from under headlights  :y
Bumbazor
  • Worksop
« Reply #3 on: 01 January 2009, 14:09:52 »
Thanks guys, thought I'd bagged a cheapo conversion with bumper for £40 but reckon I'll be looking at least another £100.
Unless I chop and grind that is!
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #4 on: 01 January 2009, 18:28:21 »
pressume wings are the same then? just diff shape to headlight where it meets extended bonnet? :-/
ngrainqey
  • rotherham
« Reply #5 on: 01 January 2009, 23:33:30 »
the facelift headlights have a narrow angled flat along the top edge into the bonnet to the end of the bonnet- the lights look like the lense is at a steeper angle (tryin to compare from good pics on my phone) also it looks like theres more of an angle from the outer corner of the healight to next to the grill if that helps
V8!!!!
Danny
  • Wigan, Greater Manchester
« Reply #6 on: 02 January 2009, 16:34:21 »
OmegaVXR has this done, he's the best to ask, he has an MV6 front bumper as well
