Author Topic: Bouncy-Bouncy  (Read 2517 times)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Bouncy-Bouncy
« on: 24 December 2008, 13:42:33 »
Had new rear shocks a few weeks ago, quality brand (cannot actually remember which)
Ever since I thought that with a mild load in the back it felt a bit lively but figured that it was probably the result of new shocks doing their job & stopping the body from wallowing over bumps
Last night with 3 passengers & a Pa system in the back it was all over the place & rear seat passengers reported that it felt as if the suspension was bottoming even over mild undulations in the road surface & the whole car felt bouncy
It sits level when empty & loaded
What could be the cause?
I know that the new shocks were estate ones, not saloon so can rule that out
markey mark
  • SLady bitshorpe north lincs
Re: Bouncy-Bouncy
« Reply #1 on: 24 December 2008, 13:49:36 »
are your springs broken ?? you would have to get some wieght in to bottom it out !! are you sure the shocks were right ones ?? saloon ones are much longer than estate ones so would bottom out much easier  :-?
Pitchfork
Re: Bouncy-Bouncy
« Reply #2 on: 29 December 2008, 11:54:19 »
Took it back to garage this morning
Up on ramp
Springs not broken & correctly located
Suggested again that perhaps they were saloon shocks supplied in error
Fitter adamant that he had asked for estate type & given Reg. No.
Again suggested that we check part Nos. to eliminate possibility of incorrect type
Called supplier (Boge manufacturer BTW) & guess what?
They have supplied saloon shocks!
Correct ones ordered now :o :o
fife_omega_v6
Re: Bouncy-Bouncy
« Reply #3 on: 29 December 2008, 14:33:59 »
thats terrible that thought the fitter would have checked the part number were correct before removal...
[img name=signat_img_resize]http://i404.photobucket.com/albums/pp123/fife_omega_v6/IMAGE_00054-1.jpg[/IMG][img name=signat_img_resize]http://i404.photobucket.com/albums/pp123/fife_omega_v6/IMAGE_00059-1.jpg[/IMG]
Pitchfork
Re: Bouncy-Bouncy
« Reply #4 on: 29 December 2008, 15:49:48 »
We all trust others to know what they're supposed to know do we not?
For example Israelis to know something about Palestinian civilians' right to live & not be bombed indiscriminately from American supplied aircraft while the rest of the world merely mutter tut-tut but fail to take any action for fear of loosing votes at the next election >:(
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Bouncy-Bouncy
« Reply #5 on: 29 December 2008, 21:56:35 »
True...on the fitters and the human rights comments :y
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Bouncy-Bouncy
« Reply #6 on: 30 December 2008, 13:54:13 »
The estate rear shocks are really a lot different length than the saloon ones so the fitter should have spotted this. IIRC the saloon one is so long that it simply does not go in to the estate, not even close!
Pitchfork
Re: Bouncy-Bouncy
« Reply #7 on: 30 December 2008, 17:52:17 »
Oh yes they do! :o (shocked- geddit?)
benbrunt
  • Oldham
Re: Bouncy-Bouncy
« Reply #8 on: 30 December 2008, 19:16:14 »
You pay peanuts and you get chimps for employees!
Was it a big named garage that fitted them?
<marquee>[img name=signat_img_resize]http://farm4.static.flickr.com/3208/3130811192_b672fbed66_m.jpg[/img]
Gas Guzzler, I love the stuff!
Pitchfork
  • Barndances &amp; Morris
Re: Bouncy-Bouncy
« Reply #9 on: 31 December 2008, 09:57:40 »
No, it was a local garage & the mechanic is my usual one who in the past has been excellent including rescuing the motor when it was hydrolocked. I will not apportion any blame to him or pay him in peanuts (salted or otherwise)!
Pitchfork
Re: Bouncy-Bouncy
« Reply #10 on: 03 January 2009, 16:41:08 »
Had correct shocks fitted this morning
They are considerably shorter than the saloon ones that were supplied & fitted in error
Not been for a run fully loaded but it feels much firmer than before & no longer wallowing around at the back, which makes me ask is a saloon a 'softer' ride than an estate?
